Post an ori file of the car
I have a Ecm 2001 driver fot a Mitsubishi Colt 1,6 16v without rpm limiter I know where i find the limiter, but I don't know how I set the adresslines in Ecm this is what a friend say on the forum
Your limiter is at location 4139h. There are two bytes, 02h, 26h (0226h = 550d). Divide 4750000 between that number (550) and your limiter should be 6800 RPMs real number, but 7000 with the variations of the analog tachometer.
i have added the driver whitout the RPM limiter
0x4139h = 8F Not 02
Offset 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
00004096 02 03 06 07 16 2F 90 CA 48 EB 4A EC 44 45 46 E9 ...../??H?J?DEF?
00004112 D2 D3 CE CD CF CC 4D D1 E7 E4 E3 30 DF A6 E5 40 ??????M????0??@
00004128 DB DC ED EF F2 F1 91 D6 D7 AA AB 8F 93 94 A8 A9 ??????‘????“”??
00004144 D0 5D 5E 5F 60 61 57 58 54 55 CB 51 52 53 8E 04 ?]^_`aWXTU?QRSŽ.
You need to tell me the limiter offset and i think i'll be able to update the driver
The offset is the position in the file in hex!
On the driver you got Advance at 0x6b00
May be you can find it there:
ECM2001 6.3 (SW for ECU remapping. Include 9.700 drivers!)
Hotfile.com: One click file hosting: DATA_EXPLORER_MANAGER_4.50.RAR
Here is the same original file you posted, except that it has a modified RPM limiter to 8000 RPMs for you to try (poor, poor engine).
As far as I know, there is no need of checksum correction on such file (guessing that it is for a 1990-1995 car).
Also, there was a typo in the previous information I provided, the base was not 4750000, but 3750000. So, the calculation is 3750000/(MSB,LSB) Bytes. Such number is always based on the crystal oscillator frequency.
Good luck
3750000 that's something else that I thougt. I was making the driver and
filled in 475000 and when I loaded the driver I got a RPM limiter of 8600rpm.
But now I fill in 3750000 and I get 6800 rpm.
Thanks for your help and time.
greetz,
Alex
