Results 1 to 13 of 13
    Jul 2010
    melbourne, australia
    Default toyota yaris key programming
    Hi I am a noob here & wanted some help.
    I have a 2008 toyota yaris with no keys, they were lost.
    I have a new key from toyota but need to learn it to the vehicle.
    I am told I can use a programmer to reset the ecm to virgin mode & then learn the keys.
    I want to know if this is correct & what machine would you use, I have been told the sbb or the t300, but the suppliers dont really know if they will work.
    and if one of these is suitable, is it simply done via the obd port or does the actual epprom ned to be removed?
    Nov 2009
    you need simply sbb to program yaris keys..but you need also pin code to do that..so maybe you'll remove eeprom to extract pin code then program your keys..
    Ous**
    Jul 2010
    ah that is what i needed to know, so the sbb will work. is there any other way to aquire the pin?
    i would prefer not to remove the eeprom as I have never done this & also dont have anything to read the data with.
    what would i need to read the eeprom?
    and are teh usually soldered ?
    Jul 2010
    this Yaris is UK version or Japan?
    Jul 2010
    it is an australian version
    south africa
    buy toyota dongle (orange ) 50 dollars and code new key.
    Jul 2010
    I was actually told initially that this wouldnt work but I borrowed one & it worked perfectly!
    so I am very happy, i was unsure if I had a 4c or 4d transponder, turns out I had 4d & car is going. thanks for your help
    DK Veteran JIMMYQ's Avatar
    Mar 2008
    Quote Originally Posted by drivesure View Post
    does this work even if you have no keys at all? meaning a new key with the relevant transponder put it in the ignition and the dongle programs it? without the need of reading the eeprom in the ecu?
    if so any links to it please?
    Bishop c4's Avatar
    Feb 2010
    chess board
    ray-ray's Avatar
    Nov 2009
    98 to 02 is 4c and 03 to 09 is 4d 67 or 68 and 10 and newier " g" chip.
  11. #11
    Ashraf6119's Avatar
    Nov 2009
    UK
    Quote Originally Posted by cqae View Post
    Could you please explain how did you use this tool, i mean step by step to program the new key in.
    Or, if there is any good link which explains clearly how to use this tool would be very helpful to all here.
    Also thanks for giving feed back that you were successful in using this tool.
    Ash
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
  12. #12
    Mar 2008
    ive ordered one just waiting for it to come should be here in the next day or will see how good it is and if it does what it says just shound a bit too good to be true for the price
  13. #13
    Sep 2009
    Tcode with 8 pin inout code calc will work but some times abs lights go off, ie turn on. toyo tis fixes it. Just if thats what you have on hand.
