Results 1 to 10 of 10
    Aug 2010
    China
    Default XENTRY DAS 05/2010
    hello all.can you give me a hand as follow:
    1、I installed XENTRY DAS 05/2010 version to Star Diagnosis Compact 3 ,it worked with USB cable,but the wireless didn't work.then I set the parameter as leaflet,but it still didn't take effect.
    2、 the system disks(D,E,F) were hide after the installation of DAS ?(system disks C was normal)
    Is any one knows how to solve these problems?
    Thanks & Best regards!
    Junior Member dg-power's Avatar
    Aug 2009
    Try renaming letter drive paths from Hdd management, or use Easeus partition (d: Recover, e: Wis ,FAS)
    DK Veteran wsc's Avatar
    Aug 2009
    GR
    Quote Originally Posted by saejetcar View Post
    Run->regedit->
    HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies
    Click on "Explorer".
    Leave (Default)
    Leave (NoDriveTypeAutoRun)
    delete all others and restart computer.
    Smart car engineer ,
    DK Veteran gmatj's Avatar
    Dec 2009
    Heaven (is place on earth)
    Quote Originally Posted by wsc View Post
    Run->regedit->
    Leave (Default)
    Your answer was of great help however :
    If you have copy /pasted your answer please do refer to the author and/or direct to the original link
    This is justice m8.
    Aug 2009
    GR
    Quote Originally Posted by gmatj View Post
    This is justice m8.
    M8 this solution has posted several times for many members.
    Thank you all
    Dec 2009
    Thank you all
    Same sugestion goes to the "many members" and only for this example.
    All the best
    G.
    Aug 2009
    GR
    All the best
    G.
    Tell us now that you post all other knowledge is that you got after Birth.
    As you wish, to close here.
    thank you again
    Aug 2009
    GR
    This is justice m8.
    U are right m8 thanks:
    I think AUTHOR is microsoft?or not?
    Hide Drives and Partitions - WorldStart Computer Tips and Computer Help
    Dec 2009
    thank you again
    I was polite enough and made a suggestion to you. And to everybody else. So I do not quite get all this "birth knowledge" talk of yours.
    You take it or leave it - it is as simple as that - but whatever you do it is good manners to respect others who have posted 4-5 times as much as you have.
    I leave it here and of course I do not intend to continue. This is not the scope of DK - The scope is to help others (and at the same time give others the credit they deserve!)
    Aug 2009
    GR
    You take it ir leave it - it is as simple as that - but whatever you do it is good manners to respect others who have posted 4-5 times as much as you have.
    I supose you are right as Senior Member.......
    Also i think i am not rude in any and i dont need credit in DK or other forums!
    I just helps when i know.
    I hope u ll do the same.......
