Results 1 to 8 of 8
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Default Clio III 2007 problem
    Hi Guys
    got the above vehicle with 1.5dci engine in it but wont start it has ahd an accident and airbags have gone off i cant seem to find an inertia switch so prob not got one but the hazards do flash when the ignition is turned on so i think it is getting the trigger from the srs module so has anyone one here had this problem and is it the srs module that is stopping it running
    many thanks
    Member Turbo5GT's Avatar
    South Africa
    Cut off is inside airbag ECU. I have had some clio 3 start with old airbag ecu, but i have also had some not starting until new airbag ECU was fitted. If you unplug the small connector on the airbag ECU the indicators will stay off when the ign is turned on. Also make sure there is no damage to the front of the car eg. Wiring, Fuses.
    Hope is can help.
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by Turbo5GT View Post
    Hope is can help.
    so if i unplug the ecu will it run or does it need to have the ecu connected
    South Africa
    You must leave the large connector in, just unplug the small connector to stop the hazards coming on.
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    ok thanks but will it run again though or do i need to unlock the srs ecu to get the car to start again
    many thanks
    do you have can clip??
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Yes i do have Can Clip v99
    you go to ecu injection and erase all dtc even if there is nothing
    this is not a problem into airbag ecu
