Results 1 to 4 of 4
    Mar 2010
    Default Fiat croma 120cv edc16c39 FAP
    Hello could you help me I have to disable the FAP from original map of this machine to make a change ... perhaps using ECU safe!
    could someone help me?
    Mar 2010
    Quote Originally Posted by mariooo View Post
    Bosch
    EDC16C39
    1037386776
    Potreste controllare che il file ori con fap off ? corretto ?? io credo vada bene ma vorrei il vostro parere.. qualcuno ha modo di verificare se va bene ?
    You may check the original file with fap off is correct? I feel okay but I would like your opinion .. someone has way to check if it works?
    bmw320d's Avatar
    try it and report
    Mar 2010
    Quote Originally Posted by bmw320d View Post
    try it and report
    Ciao bmw320 ma tra il mio file ori con fap off e il tuo con fap off che differenza c'? ?? io mio ? sbagliato o giusto ? a me sembrano uguali ...
    Oltre al fap rimosso da ecu dalla marmitta cosa si smonta ?
    Hello bmw320 but between my original file and your off with fap fap off with what's the difference? I mine is wrong or right? I look the same ...
    In addition to fap removed from the ECU exhaust what can be removed?
