I checked both,thanks
Problem solved.
Just remove rs485 box, there is nothing inside.
Hi riddler
That was a cool comment you made!!!!!
Mr Osama bin has been all over the place
http://www.digital-kaos.co.uk/forums...ml#post1260280
and
http://www.digital-kaos.co.uk/forums...ml#post1260243
This one is cooler
All the best m8 after quite some time
Cheers
G.
P.S. Premierd are you watching ???
Sure am ............
Hello members,
i have buy a Star C3 scanner for low cost.
The scanner works for over 1 year fine, but now i have a error and no warranty.
I don?t can connect to the car anymore.
I have a second mux and i have tested the cables and they are OK.
My blackbox is empty, there is nothing inside.
I have put in attachment a picture from error and a selftest from mux.
Please help me to solve the problem.
best regards Cheng
open multiplexer
check transistoren and pcb
you can see where broken is
Many thanks for the usefull info.
regards Cheng
DSC00978.jpghello, anyone has the number of pins of the 4 wires in the photo?
My clone will not work in hhtwin, perhaps the problem is the absence of 4-wire saw that when I connect it keeps saying "wrong cable"
sorry for my bad English are the Roman![]()
If you are running HHT from an ordinary laptop with a serial port, you do not need those wires and the lack of those wires does not cause HHT problems.
But is your tool otherwise the same as on the photo, most of those "high quality clones" have those (power feed) wires between the round connectors.
Hi, Meanwhile, thanks for the answer, but how can I fix this? The system was tested with another mux and it works fine, what I should change or repair to my mux?
So far you have only explained that your mux does not work with HHT. You could post photos from your circuit boards so that experts can identify the product and you could explain which cars you are able to test currently.
Have you tried your mux with a different 38-pin cable (assuming that is the one you were using with HHT when you got problems).
Hi, Mates
I'm so glad I found this thread.
I also have test run OK but no connection to the car, Green light is on.
Please take a look at my mux's pics. I'm missing one of the diodes at V014. Is that my problem? Anything else?
Thanks much
