I'm also going to by mux but I face a dilemma about which mux to buy: c3 of sd connect.
C3 has already tested and as others experience shows it is reliable(well, more reliable than Its successor sd connect). Also, It's ease to repair when is has broken or blocked.
But, as Patrian said:
EVEN and with ORIGINAL Multiplexer CONNECTED in any Laptop you CAN'T to use Xentry for W204, W207, W212, W197!!!!! .
It means that you can not use c3 for w204(lunched in 2007), w207(thnk 2009), W212(2009), an btw, which is this w197?
so, is that mean c3 going to absolute and Daimler gives green light to sd connect?
As some says, if sd connect get blocks it has to be unlocked on hardware level which is expensive and there is no software solution.
So, please tell your opinion. which way to go
