Page 9 of 13 FirstFirst ... 45678910111213 LastLast
Results 121 to 135 of 185
  1. #121
    The erorr code I get when try to connect is
    Fault(1.3)3.516.2005 anybody know what is mean?Thanks
  2. #122
    diagnoza_auto2000's Avatar
    Sibiu
    K line diodes shorted to ground this its why you have good Caesar Self test but you cannot accest the cars modules,but you can see the voltage of battery
  3. #123
    Where is located this diode please?
  4. #124
    Sibiu
    Put your mb board picture and i show you where is it.
  5. #125
    Sibiu
    Solution for your problem is here.
    After this if its still not work i will tell you next step
  6. #126
    I checked before this diode off board and now too on the board:
    small zener has 5 V and big zener 12V
    big black 12V
    this I checked on board when power is on the obd plug!
    What are you think is it ok?Thank you for your help what is the next step?
  7. #127
    Sibiu
    As you see in the picture on both red diodes you must have 12 V when you have powered your mb unit on the car.
    Make me a picture and show me where did you have 12 v and where 5 v?
  8. #128
    This is not mine but diodes are the same
  9. #129
    Sibiu
    M8 this is c4 i talk here about c3 look my picture.
  10. #130
    I don,t uderstand what you mean,is it voltage different on c4 or should I upload my pictuire look,s the same this part of board?
  11. #131
    Sibiu
    Schematic is diffrent sow its not the same think.
    Upload your mb board pictures
  12. #132
    sorry for bad rezolution
  13. #133
    Sibiu
    Btw your mux its a D4(low quality mux) and its a little more dificult to repair then a D3.
    Check the picture.
  14. The Following User Says Thank You to diagnoza_auto2000 For This Useful Post:
    mexanico1971 (15th November, 2013)
  15. #134
    I will check and reply
  16. #135
    Hi mates,
    now is my turn ... My china's clone is something special - it has usual rs232 cable from laptop to mux (no rs232-rs485 converter), it don't support win-hht, it don't pass mux test at all - "no D part is connected" says... BUT! It works good enough with any cars with obd2 socket, with trucks and vans (14 pin and obd cables), and something strange works in e-class with 38 pin cable - it could't find some existing ECUs and found not existing... I had broken cable from laptop to mux, but recreate it as I could guess... Maybe pinout was wrong? Pictures attached:
