Results 1 to 15 of 26
    GMXcool's Avatar
    May 2009
    Default New version UPA-USB Device Programmer v1.2.0.53 Beta 09-Sep-10 !!!
    Version 1.2.0.53
    - Windows XP/Vista/7 both 32-bit and 64-bit (windows 98 is not supported)
    - Installs and runs compiled scripts (TMS Script only) and script packages
    - Script IDE including visual form disigner, debugging...
    - Added some new devices
    - Device tree
    - Fixed some bugs
    TMS Script feature details:
    - Integrated Development Environment (IDE) allow creating script projects with multiple cross-language scripts (Basic and Pascal) and forms
    - Visual form designer and Object inspector
    - Integrated debugging system in the IDE, including breakpoints, watch viewer, trace into libraries, etc.
    - Component palette
    - Integrated syntax highlight memo with automatic code completion
    - Supports try..except and try..finally blocks in script
    - Most of Delphi system procedures (conversion, date, formatting, string-manipulation) are already included (IntToStr, FormatDateTime, Copy, Delete, etc.)
    - You can save/load compiled code
    - COM support
    - Support for calling DLL functions
    Regard
    Prussia
    Is this something you invented?
    Or are you saying this is from the original manufacturer?
    Or copied from hcip?
    May 2009
    I believe gmxcool is saying that a new beta of the software is available from elrasosft for UPA-USB, it came out today.
    Eric
    Oh and by the way if my post has been at all helpfull it will encourage me to respond to posts if you remember to please press the Thanks Button
    GMXcool's Avatar
    May 2009
    Yes, for original programmer
    Regard
    Quote Originally Posted by TULGEYWOODMAN View Post
    I do not see anything new
    ELRASOFT Products
    2008 finish update
    is new version
    only for the customers - after logging in
    einet's Avatar
    Hello
    How can give me more infos about this software update for " 78K0/HC912 Software update"
    The Package includes:
    - 78K0/HC912 Software update
    - 78K0/HC912 Adapter
    - uPD780824/6/8 test board
    - uPD780973/4 test board
    - 68hc912 112pins test board
    einet
    upload this!
    Russia, Saint-Petersburg
    Anybody can upload v1.2.0.53 ?
    Thanks a lot advance!!!
    please upload the new version!!!
    Default New UPA usb
    Hi new software upa usb
    do not update clone upa usb
    isak2009
    Thanks!
    Why it will not work with clones?
  13. #13
    I test it clone upa is blocked no updat it if you have clone one
  14. #14
    bricolo's Avatar
    france
    HI
    in attashment you can found user manual
    for this version
  15. #15
    Top Poster Motika's Avatar
    Yorkshire, England
    I seem to be having an issue with this version of software. I'm trying to program an L56R albeit as a 93C56 (i've seen on this forum that this shouldn't be an issue) and it can only read but is unable to program(write) and its erasing everything in the memory. Strangely enough if i try to program/write as 93c56x16 it is able to do so but the information gets altered somehow. Before you ask i'm using the original UUSB from elarasoft. I've tried going back to the earlier software version and for some reason it is saying device not recognized even though the driver is correctly installed. I've tried another pc with windows xp still no joy. Has anyone had this problem before if so how can i resolve this issue?
  16. The Following User Says Thank You to Motika For This Useful Post:
    djimhoff (16th September, 2014)
