Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
  1. #16
    Sep 2010
    So first, excuse my English
    So it all started with the first error :
    Control Module Part Number: 03E 906 023 D
    Component and/or Version: SIMOS91 1.2l 4V 9510
    Software Coding: 0000061
    Work Shop Code: WSC 00788
    1 Fault Found:
    16555 - Fuel Trim: System Too Lean: Bank 1
    P0171 - 006 - Short to Plus - Intermittent
    I appeared for about 2 -3 times, and after I removed it has not appeared. about 2 weeks and I still continue error occurs :
    VAG-COM Version: Release 409.1-S
    1 Fault Found:
    16687 - Cylinder 3 Misfire Detected
    P0303 - 009 - Open or Short to Ground - Intermittent
    car is a 2007 vw polo 9n3 1.2l engine 47kw BME
    if you can help me get rid of this error is all, thank you help me
  2. #17
    Sep 2009
    Mixture is wrong and that can cause misfires.
    Check hoses around inlet manifold and check exhaust manifold for leaks.
    Can you read data? Does this car have a map- or maf-sensor? Does the map- or maf-sensor show valid data?
  3. #18
    Member disv55's Avatar
    Nov 2009
    I have again looked at the various control units and have different error codes. EDC17CP has special DTC, so no normal CAN DTC. This had been a UDS is iso 14229 protocol. Your link did not the new DTC. Have you any idea how to get the code from VAG COM or VAS can export software.
    Yours sincerely,
  4. #19
    Jul 2010
    Brest BY
    Please help me with unpacking and packing the file codes.dat VCDS 10.6. I want to translate it.
  5. #20
    Sep 2010
    hi
    how does the adjustment for the ecu
    ecu polo 7 03E 906 023 AH 5WP40920
