Page 1 of 41 12345611 ... LastLast
Results 1 to 15 of 602
    carradio2001's Avatar
    France
    Default VW MID EU / RCD310 HELP
    Hi guys,
    Please calculate code RCD310
    VWZ1Z3H3250190
    7 647 239 360
    I know code address, I know the code cannot be changed, please help !
    Carradio2001.
  2. The Following User Says Thank You to carradio2001 For This Useful Post:
    salaheddine ele (8th July, 2018)
  3. #2
    einet's Avatar
    When you now the adresse!
    Way you d?ont change it!
    And for waht you need code! when you now the adresse!
    einet
    France
    Quote Originally Posted by einet View Post
    einet
    Because I don't know the ALGO !
    In my file, the code is CD 06 2B 01, don't know the code !
    Also, I don't know WHY the eeprom cannot be cloned, the code cannot be changed. I have more files with known code and this not helped.
    The special tools which read the code like MARTECH I think not read directly CD 06 2B 01 and read within another method, ask directly the radio what is your code ? or read directly in ASCI, code 1234 and that's it.
    Personnaly I don't think exist someone which know this algo, it is too newer and this radio not soo much for making an conclusion.
    Carradio2001.
    France
    I working on this algo, somebody can confirm the next codes ?
    Let's help together to find this ALGO:
    CODe 1 number 2 number 3 number 4 number
    1852 68 93 50 FD
    1858 2D 95 A6 44
    1713 33 1D 9A BB
    0954 AF AC 21 B1
    xxxx 39 12 74 C9
    xxxx 2D 0B 30 33
    xxxx 64 2B AC C3
    1119 1C 95 12 3E
    xxxx CD 06 2B 01
    xxxx 6B 93 A3 A1
    0687 40 FD 90 C7
    xxxx 0F 3B 0E C4
    xxxx D2 4E 30 33
    0400 C3 01 59 6E
    xxxx 3C FD B0 2C
    0330 C9 E7 E7 FA
    xxxx A5 C3 46 78
    0363 66 C6 52 FD
    0692 2E C7 0C E4
    0453 F6 36 AD 25
    0506 1F 88 C8 19
    xxxx 55 E6 FE AF
    xxxx 58 81 AE 77
    xxxx 5B B5 AA B6
    1287 B1 F3 29 34
    xxxx BA 6A 98 CE
    xxxx FF 74 46 BC
    Carradio2001.
    algeria algiers
    dear freind im working on it from last year, no chance, but somtimes when i am with a good client i search manually the code, one by one,but reset conter eatch time ,
    one day i desolved resistance from pin 3 ,radio don't shows errors, so i tryed all codes, it worked
    may be code is in another part in radio, so if you changed some values to clone another code,radio will not turn on
    crazy algo
    France
    Hi !
    Somebody says the code is in MCU, only reset counter is in eeprom, others says the code is in both: MCU and eeprom.
    My opinion is code and reset counter is in EEPROM and code cannot be changed because have somewhere a checksum. The radio know always to check and modify the checksum, but we not ! or the code is in MCU and if you change in eeprom not egual and bad code result !
    Another secret people tell me they discover the algo BUT not tell anyone because it's money arround and want money on every dump for which calculate the code or sell own software !!!
    Will discover this in near or away feature ...
    Carradio2001.
  8. The Following User Says Thank You to carradio2001 For This Useful Post:
    mmtsstyle (5th June, 2019)
  9. #7
    branco's Avatar
    paris france
    code can be changed and is in eeprom
    solution exists but is on private
    (one friend send me code from dump )
    regards
  10. #8
    ISTANBUL
    Exclamation
    Let's see who will solve this business
  11. #9
    algeria algiers
    Quote Originally Posted by branco View Post
    regards
    he send you code from dump, cause serial is in dump, no chance to use this dump to clone another, many knew code adress but can not chang the lines to have same code
    the man who helps you read serials from your dump send you code, try to give him only code lines and show if he can calculate it
  12. #10
    alexics's Avatar
    Kidderminster
    It is not straight forward. It is not only the code addresses that are interlinked. You need to look to the past to discover the present.
    It does not matter how slowly you go so long as you do not stop - Confucious
    You will move very slowly when facing a brick wall - Alexics
    Ford Visteon V series LOCKED - SORTED
    Ford Visteon V series CODE OFF - SORTED
    Ford Visteon V series recoding - IN PROGRESS
    Ford Visteon V series calculator - IN PROGRESS
    VW Blaupunkt calculator - IN PROGRESS
  13. #11
    branco's Avatar
    paris france
    Quote Originally Posted by dj_meteo View Post
    no at all
    I got original code from serial by friend "einet"
    so I asked to my other friend to change the code
    he did it
    regards
  14. #12
    France
    I put table ONLY for codes, there is a more strings inside eeprom more interesting which are checksums and error counter.
    Carradio2001.
  15. The Following User Says Thank You to carradio2001 For This Useful Post:
    schumy1502 (13th December, 2016)
  16. #13
    France
    Hi 1
    WHY everybody not tell the TRUTH ?
    The RCD310 can be decoded easily from the dump.
    In this moment only a few know the algo BUT in the near future will know more and one time will know ALL.
    I asked for help. Some people can help or someone not. I will make ALL what I can do to find this algo. AFTER that I am intention to put it FREE becasue NOBODY wants to help, NOBODY want to give me ONE CODE from dump ! It is a cruel world.
    Carradio2001.
  17. #14
    laxitylabs's Avatar
    @carradio2001
    hint for you: 6B93A3A1 is equal to 0065.
    ciao
  18. #15
    blackpirate's Avatar
    Jun 2009
    Quote Originally Posted by carradio2001 View Post
    Hi 1
    Carradio2001.
    yes! it is!
    it started with you!
    why your calc its not shared?for free!!!!!
    you shared only with your friends..
    here, on DK, we are all friends!!!!
    Shareing & Help= this its all about on DK!
    you will say that its your your, i agree with that, you can do anything you want, share it or not!
    you wanna help us all?
    you can start by shareing Calcgen!
    my 2 cents...
    BP
    If freedom is outlawed, only outlaws will have freedom!!!!
  19. The Following 2 Users Say Thank You to blackpirate For This Useful Post:
    salaheddine ele (8th July, 2018), ubistvo (10th May, 2016)
