Toyota techstream serial HELP - Page 2
Page 2 of 42 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 619
  1. #16
    drakov's Avatar
    Aug 2008
    try this one:
    a19efbe4f0d6cf78539a2854dbd55ed617201010091130
    also check your ID hasn't changed
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
  2. #17
    DK Veteran trigital's Avatar
    Default ID
    The ID hasn't changed and this key also do not work.
    Thanks,
  3. #18
    drakov's Avatar
    Aug 2008
    you are activating under USA screen and not europe? other than that I have no idea sorry.
  4. #19
    Quote Originally Posted by drakov View Post
    I activated within EU, but maybe because I update from an already cracked version.
    I will try to update from V5.01.001.
    Thanks,
  5. #20
    drakov's Avatar
    Aug 2008
    key activation only works if you do it via USA so try that with the keys I gave before
  6. #21
    Yes, it works!
    But when I try to connect (without car) a pop tell me that a network connection is required to use Techstream software, so I have only 29 more times left!
    Into the US settings, I can find the EU brands (corolla, avensis,et)?
  7. #22
    drakov's Avatar
    Aug 2008
    Activate in US then switch back to Europe
  8. #23
    If I switch to EU, it ask reg again.
  9. #24
    Newbie autosale's Avatar
    Hi, please serial key:
    VER. 5.10.029
    Thanks!
  10. #25
    drakov's Avatar
    Aug 2008
    Quote Originally Posted by autosale View Post
    VER. 5.10.029
    Thanks!
    Try - 09144a195fc3dc509bd08a001fdb8a3253201010120754
  11. #26
    Hello, please serial key:
    VER. 5.10.029
  12. #27
    Thank drakov!
    This key in US tell me, a network connection is required to use software, if switch to Europa, it ask key again. I patch mainmenu.exe and no longer requires registration key on US or Europa .
  13. #28
    Thumbs up
    try version 5.01 don't need network
  14. #29
    hi i have the 5.01.001 and put the update 5.10.029 and the software id is 4c4c4544-004a-5110-8031-b2c04f304b31 thanks
  15. #30
    Hi, If someone could help me please, I also need serial for techstream 5.10.029
    tanks.
