hello techstream key
4c4c4544-0038-3910-804bb1c04f474431
4.20.018
thaNKS
4.20.018
thaNKS
Please generate code for me too
ID 01692CB3-34B1-DB11-8312-00023FEB69F8
Version 6.01.023
Other Region, Europe region
Thanks for advance
ver:6.01.023
please help me with my code i have toyota techstream 6.01.023
00c25EE1-50f8-df11-9A23-00266C9840C7
For who need activation key.... make search in forum threads...already posted the solution how find the activation key with Winhex in pc memory !!!
So simple mates.....
Good luck
Hi, help , I also need serial for techstream
MY software ID is
A4C6C600-C1C2-81DE-3AFA-90E6BAECE0D7
ver. 5.10.029
Hey! Guys. You could figure out the license key code on the section Techstream Activation. This section already give the information how to figure out . How to get the serial number. I tried few times and I figure it out. Before looking for the answers. search around. And try......
Please friends I hope your help to turn Teachstream 6.01.023
ID SOFTWARE: 4081DB10-97CB-DE11-8A9F-0024BE7FAC52
THANK YOU
please i need key
Hi ,i instaled software V 6.20.020
My software id B40C367B4BFF2A01A2404BC1FDC5E09B
Manipulation with WinHex doesent helpp
41C160C1C755C4BE06B448C24CFB549A17201010091130=wro ng
D072AC35C683B19B0D3711CDECEA9B9817201010091130=WRO NG
Who can helpp with it ?
Any idea ?
I find this solution from another forum...
copy and paste here :
Start your Teachstream.
Press "Software Registration".
Write this Key (its my key) 647e0b590258936f3e9ec7b1819dc12c17201010091130 and press OK.
Teachstream will not registred, but it generate your key in RAM.
Start WinHEX. Go to Tools -> OpenRAM. Choose mainmenu.exe, and choose Entire Memory and press OK.
Then open menu Search and search "LicenseKey". It is the FIRST part of your key.
You find some like this: LicenseKey=1b6bab99a04215e85ce96ef6a5f03129.olVer= 6
for me it was : 1b6bab99a04215e85ce96ef6a5f03129
(NOTE: you can find 2 different string LicenseKey, try use it both, but i think the first finded string, it is yours correct).
Near of this you can find second half of your key.
After scroll up or down you will see text like this :
"38f558f0011a2b92d180909628b8315dMyCarIsFantas tic 17201010091130"
The text after "MyCarIsFantastic" is the SECOND part of your key: "17201010091130".
(NOTE: The text may be another... some like: Toyotaisfantastic)
And whole your key will be Like this: 1b6bab99a04215e85ce96ef6a5f0312917201010091130
write it in Teachstream window and it will be registred.
try again mate....
see post #54
