I've read ecu on the table, not from OBD...
Eprom is in the same archive
Yes, Files are 100% good, maybe someone else has a good ECUsafe or another program and can check my files?
i have interest in the same car to remove dpf. 1.9.3.0 ecu safe is unable to remove dpf on this car. is it necessary to unplug the sensors after dpf off file will be written?
How programmer you read Motorola flash?
MPC.bin is not empty. But it size must be 448 kB (256+192).
May be find in X-prog settings some options?
