Results 1 to 15 of 17
    Default Volvo Vida 2008c problem with communication tool parameters
    Folks, I have a problem with seeing the communication tool page of Vida 2008C. After installed Vida on a PC with Windows XP, SP3 and I can see all other pages, except the page "Communication Tool". Please, take a look at the attached screenshots.
    Can anyone help me to make this work without having to install a fresh Windows XP with SP2?
    I tried the following, but without success:
    1. I wanted to uninstall IE7 and install IE6, but it seems that with SP3 this is not possible. Is Vida 2008c supposed to work with IE7?
    2. I downloaded and installed the latest JAVA, but still nothing .
    Top Poster + Iroll's Avatar
    Default Hi,
    Why not use VIDA2010A?
    Try:
    Add or Remove Programs: select VIDA click Change then Repair.
    VIDA Configurations: click save.
    IE7
    Clear the cookies and temp files in IE.
    Internet Options/Advanced Tab (Restore Advanced Settings) (Reset IE Settings)
    You will have an Information Bar Security Warning starting VIDA ? Intranet Disabled? ?Add-On Disabled? select (Enable Intranet Settings, Run ActiveX Control)
    Or just install 2010A!
    Please! Don?t forget the ?Thanks Button?
    Default Hi,
    Quote Originally Posted by dragomirg View Post
    Any luck on 2008C problem?
    Quote Originally Posted by Iroll View Post
    Yes, absolutely working, thanks a lot for the useful tips!
    What I did to solve the problem:
    1. I ran the VIDA setup again and selected "Repair".
    2. Meanwhile, while the Repair process was in progress I also followed your advice about IE7 - Cleared the cookies and temp files in Internet Options/Advanced Tab (Restore Advanced Settings) (Reset IE Settings).
    And the next time I started "Vida All-In-One" I could see the Communication Options. Thanks once again!
    Default Hi,
    Quote Originally Posted by XCHASE
    Hi, I saw a few of your posts regarding vida and you seem to be pretty knowledgeable i have 2010a installed but the diagnostic tab is not enabled, i do have an old vct hooked up. just wondering if you might know of something, thanks.
    Look at my #2 post.
    Oct 2010
    But s there any fix for the diagnostic tab missing? as in the first picture? 5th tab from the top being grayed out?
    You need to clear your IE cache, delete cookies and temporary files.
    Default Hi,
    Sorry!
    Read or Enter a Vin #
    Default Hi,
    Quote Originally Posted by XCHASE View Post
    Profile vehicle then click on ?ok?
    Diagnostic tab will be available.
    To gain full access to diagnostics information VIN has to be read or manually put in.
    fixanycar's Avatar
    here
    Default 2010A AFTER INSTALL ON VISTA
    CAN`T START THE APP at all.
    IE says diagnose connection... Tried all the tricks described in the threads here and nothing... Right now repairing installation and see what happens
    Vida monitor in the tray stays yellow (starting)
    Oct 2008
    Greece
    Exclamation
    Quote Originally Posted by fixanycar View Post
    Volvo Vida BASIC & STABLE components that she needs:
    1. WindowsXP SP3
    2. Internet Explorer 6.0 or 7.0 ONLY!!!
    3. ALL Microsoft Frameworks EXCEPT the Latest 4.0!!!
    Regards!
    fixanycar's Avatar
    here
    I installed it on Vista Home......I thought it`s ok
    Do you think program compatibility thing any help?
    Now after repair it has lost Vida`s home directory. Vida monitor is not coming up at all. Where is my "local helpdesk"
  13. #13
    Default Hi,
    XP Professional with Service Pack 3 ?Preferred?
    Vista Business Edition Service Pack 1
    No: XP Home or Vista Home
  14. #14
    fixanycar's Avatar
    here
    Thumbs up
    Ok! Now it works on fresh XP install. I needed to patch it......
    Thanks to all for replies. I think my vista install would work if i only had patched it.
  15. #15
    Smile
    D'OH!
