HI
I need update sofware vw golf 4
I have vas pc v17 and flash cd vw v53 3-2010
???? Is posible reflash uce whitout online server code ?????????
many thanks in the advance
HI
thx![]()
you mean???
YES!!! of course you can Flashing the Car and with Off-Line procedure!!!
For this reason they existing the Flash CD's.....
About the procedure, here you are:
1. Put the DVD Disc in your Drive (or mount the .iso image file IF YOU ARE SURE for the LETTER Drive...)
and this you need to check it in EDIABAS Folder and in Ediabas.ini file!!!
2. Start "Self Diag"
3. Go 01 Engine
4. IF the DVD have newer S/W than ECU, function 19 will BE APPEAR!!!
5. 19 Control Unit S/W Update
Good Luck!
Regards!
never knew i would need to use my flash discs if i did i wouldn't have lost them........... now im having to try source them again i know they should be around somewhere but i just cant put my finger on them too much clutter if any of you guys can locate yours please share with the less fortunate thanks
