Results 1 to 12 of 12
Thread: c3 cuts out
    DK Veteran m3vuv's Avatar
    woodhall-spa lincs
    Default c3 cuts out
    Hi all,got an 02 clitron 3c 1.4 hdi in the workshop,customer says it cuts out at random,the fault codes stored were p0102 p0219 p0339 p0106 p1113,i assume this will be a bad earth/feed /multiplug ect,any ideas if this is common on these?.cheers Paul m3vuv.
    Top Poster + autoelectric's Avatar
    Greece
    Hello
    Trouble codes P0219 P0339 have to do with crankshaft position sensor. P0102 and P0106 probably caused because of the wrong readings the time that car cuts out.
    I think that firstly you have to check the crankshaft sensor.
    Ashraf6119's Avatar
    UK
    First of all what tool are you using to read this car ?
    Than the fault codes you posted here are as follow.
    P0102 Mass Air flow sensor fault.
    P0219 Engine Over speed (Incorrect Gear Change) For this fault code it looks like at some point was been over rev or, some driving error by the driver.
    P03339 Crank Shaft Sensor.
    P0106 MAF Sensor Fault.
    P01113 Diesel high pressure monitor (pressure regulation upper limit)
    It could also mean
    P01113 Intake Air Temperature (IAT) Sensor circuit open/short
    There for we need more info like what tool are you using to read this car.
    Engine Code would be also more helpful to help you.
    Just to Add have you checked the fuel filter condition and the fuel line if there is NO any leak.
    Hope this helps.
    Ash
    SP Have a look in here for your fault codes.
    http://www.pikit.co.uk/peugeotmt/psa...p%20codes.html
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    Meat-Head's Avatar
    HI
    WOULD SUGGEST POSSABLE OVER PRESSURE IN THE FUEL SYSSTEM CAUSED BY A DODGY REGULATOR.
    COMMON ON LOTS OF HDI VECHILES
    HTH
    MEAT
    woodhall-spa lincs
    Hi i was using a snap on modis,i will post the engine number tomorow,where is the press regulator located on the fuel rail or on the hp pump?,cheers Paul.
    Meat-Head's Avatar
    Quote Originally Posted by m3vuv View Post
    pump, not in the mood to link, just go to ebay and type pressure regulator
    DK Veteran Albanais's Avatar
    Tirana
    Replace the PSF1 and make sure that earth cable is well fixed on the gearbox.
    Learn from the mistakes and live the life.
    woodhall-spa lincs
    Whats a pfs1 ?.
    Tirana
    Whats a pfs1 ?.
    It is the Relay box on the engine compartment, on the left side. near the headlamp.
    Cheers
    Sorry for my bad english, Does Engine cut out during accelaration? I'd found this case few months ago, and the problem was clogged fuel filter.
    P1113 could be Fuel Rail Pressure too low
    Adhi
    Mar 2009
    Whats a pfs1 ?.
    Hi i have a same car with the same codes can you tell me what you do to solve the problem
    thank you
    Mar 2009
    Hi ihave a car with same p codes did you find any solution to this.
