Results 1 to 15 of 15
Thread: lancer 2008
    EU
    Default lancer 2008
    Anyone try or programme 2007+ Mitsubishi lancer with SBB or T300?
    I have to do one but can't find mitsubishi CAN in my SBB V32 only one I find is i sin Mitsubishi USA but not in Mitsubishi EURO
    btw: T 300 gave frong pin when do it
    thank's
    Aug 2010
    u have new ver of sbb, try MITSUBISHI US CAN, may u succeed (i have never test it), if not program it using TANGO
    DK Veteran agabna's Avatar
    some times when u try to program mitsubishe lancer and the t code say wrong pin the problem is not the bin
    the problem is the key transponder itself if u are using non originl key
    so try to use original key and try
    EU
    I get that messagge with original working key,It is CAN so probablly have different PIN
    Quote Originally Posted by agabna View Post
    all I need to know is, can it be programmed under mitsubishi USA CAN with SBB?
    thank's
    Aug 2010
    T300 Will neevr Connect With Lancer 2008
    Sbb I dont know
    ray-ray's Avatar
    as long as the chip has the rite logic no dealer key needed.ver.28 mitz. no "can" it was added on ver.31
    but have not try yet.give it a try and report back.
    nairobi kenya
    Default virgin id 46 and x431
    hi all
    am using x431 and a virgin transponder id 46 to program to a lancer 2008
    but i get error ''internal error''
    any ideas
    must i use precoded chip?
    regards
    EU
    Yes,You need precoded transponder and one for Lancer.
    L200 have different logic on it,Colt have diferent and Lancer have his logic.......
    SBB can't do it.....Euro vehicle,
    I don't know about USA market.....but I try use SBB v33 with USA CAN and can't connect to Euro LANCER and L200
    nairobi kenya
    Default used transponder
    Quote Originally Posted by davorOS View Post
    any idea if i can use a transponder from another lancer
    regards
    EU
    NO,They get locked to one car same as all ID46
    regards
    UAE Dubai
    i have try it with the SBB 33.02
    ant it works great
    but you can not use the normal 46 chip
    it should be locked for mitsubishi
    the blank chip will not work
  12. The Following User Says Thank You to ahmadalbeik For This Useful Post:
    bonux (16th February, 2018)
  13. #12
    Sep 2011
    south africa
    Default colt
    Hi All,
    Same kind of problem with Colt 2008.
    Keep on telling me execute fail, tp read fail.
    Got original Transponder blank from dealers.
    Any Help Please
    Andries
  14. #13
    keygargoil's Avatar
    there must be a fault with sbb connecting to mitsubushi can i write the key into the aerial with tm pro or tango
  15. #14
    Sep 2011
    the chip for new mitsubishis is ID46, same honda, nissan, but preparated with megacopy, ad900, tango
  16. #15
    Top Poster THeFOg's Avatar
    USA
    Hi m8's did anyone program the remote section of the lancer 2009 ? By the way the sbb 33.02 don't connect in the USA market! And I tried bridge pin 1-4 or MVP pro no go!!!
    Thank You in advance m8's.
    Sent from my iPhone using Forum Runner
    Never stop searching for something better !!!
