Results 1 to 5 of 5
    DK Veteran avtonega's Avatar
    EU
    Default VOLVO V50 2.0D 136hp - Help with diagnostic
    I have Volvo V50, 2.0d, 136hp, 2004yr in my workshop and engine cannot start!
    I checked:
    -Fuel
    -ECU (behind front bumper)
    -Fuses
    -Relays
    -DTC
    ECU is Siemens SID 803
    DTC in ecu:
    -P0A09 (I cannot clear it)
    -P1213 (Can clear, after cranking)
    -P0563 (Can clear, after cranking)
    -P2683 (Can clear, after cranking)
    Does anyone have an idea what could be wrong!
    thx
    P0A09 - DC/DC Converter Status Circuit Low
    P0563 - System Voltage High
    P2683 - Engine Coolant Bypass Valve Control Circuit High
    P1213 - ? Volvo specific
    P0A09 is a very unusual DTC. It was not defined until 2007 and it is for hybrid cars.
    P0563 may give a clue. Measure battery voltage.
    What are you using to read these codes?
    EU
    I have read DTC with:
    OBD2 protocol (using VAG-COM) and I had same result:
    Then I have scan Ecu with Bosch kts and get these...
    0A09- Injector output stage - signal too low
    0563- Battery voltage - too high
    2683- EGR - Bypass valve
    1213- Injector output stage - signal faulty
    filutek's Avatar
    Silesia
    HI
    What was the cause of a malfunction. I have a problem p1213 , replaced the ecu and no further fires.
    Aug 2015
    What cause this p1213, very strange error, the engine doesnt start, change the ecu same fault. Someone can help?
