worked with vectra 1996/1997 add keys
i had some problem connecting to honda civic and accord 2001 and ford pcm and gm work only with 2006 soltice pontiac and 30 min to make the key and then u save 30 min programing go up to 15 min but was unable to program pontiac G6 2008 and grand prix 2002 anyway get the on board programing thanks gm usa
was not able to program nissan type 4 like altima 2003
What message did you get from that 2003 Altima?
Can anyone tell me if the sbb will read reanult pin code, and does it do ford coded access? thanks
no it did not , just for program key , also for coded ford u need AD 100 PRO or other device but not SBB.
would'nt work on a vectra c accepted pin code but then ecu not found did it straight away with mvp
Was playing the other day, wiped out a key on Corsa-C ended up using Op-com to put back in , but on Op-com said ign on/off few times!
Too bored to try.
Vauxhall Vivaro - selected Reno Laguna - semmed happy.
My 'extra tokens' is at 1 now was at 5 - will it still work on zero?
I bought sbb from china, dealer said the latest version, then I wrote down the contents that sbb can do(immobilizer,remote,pin code,on each sheet).
Dont work Fiat Siena Can 2006.
