Will sbb program keys to peugeot 308 2011year?
.............no
Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
mikajna (14th April, 2017)
Nikola1309 (24th January, 2017)
suzuki vitara 1999 program key ok.
so, you did it?
worked? on peugeout 308?
hello guys.. i need your help...
i have an SBB2 Pro (China Clone), but i have problems and it does not work with the cables i have.
Some time ago i was able to test with and CK100 cable and it worked.
i them bought a new cable (supposedly for SBB and CK100), but i still have the same problem.
when i try to program/connect i always get "ECU Not Found" or "ECU Disconnected".
I know that this is a cable issue because when i tested with that CK100 cable (and old and used one), the tool worked right away...
Now, does anyone have the cable wirings that can share so that i can try and do/modify the cable to have this working?
I have a 2005 Fiat Palio, and a 2007 Ford Fusion that i will need to program the keys, and i really need to fix this tool / cable...
Can anyone help me out on this?
Just Consider helping Freely like I want to do...
Thanks and Rep are Always Welcome...
use multimeter and ck 100 cable which work and check what you need.
6841707059 576F526B 57416E5453 596F55 526F6B69424152
I Have peugeot 308 and i tried with sbb it doesnt connect with this car. so you cant programm it
I have a sbb with faulty component like the photo
And blue element in this photo , watch it is ??
Enviado desde mi iPhone utilizando Tapatalk
