Page 11 of 46 FirstFirst ... 67891011121314151621 ... LastLast
Results 151 to 165 of 685
  1. #151
    Default 2003 Honda Accord (US) model
    Having SBB key programmer V3.3.I wish to covers about 5hrs journey to program key for a 2003 HONDA ACCORD (USA model) reported of having LOST ALL the KEY.
    Reference to a transponder Guide i have here,
    Transponder should be is ID46.
    1) To avoid traveling unnecessarily Can anyone tell me if this can work?
    2) if yes to i have to reset the immo or use a pin code for this car?
    Kind regards
  2. #152
    DK Veteran marginal's Avatar
    As long as I remember I programmed a high security Honda Civic 2006 key with SBB V32 ...
    Est Modus in Rebus !!!
  3. #153
    Bishop c4's Avatar
    chess board
    Hello ngakson 2002 in my country no one report unsuccesful programing for this car everything works ok
    succes in programation no pin codes bypass everything.
    acording with my sources you dont have nothing to worry about. you can do the work!!
    (of coursse if the car dont have another issue)
  4. #154
    DK Veteran gtmech's Avatar
    Hell
    1998 toyota altezza = no
    2001 toyota window = no
    this SBB clone is without a doubt the biggest piece of S**T i have ever bought
  5. #155
    Well, it worked to program a key for a Ford Ranger 2008, but not for a Mazda 6 2006 (probably because of a wrong incode?) ...
  6. #156
    vw bora 2001 with MM4 - ok
    read pin ok from IMMO1
  7. #157
    Nov 2010
    Quote Originally Posted by marginal View Post
    Did you reset the ignition before matching the incode with the original outcode? This will cause a new outcode and incode.
  8. #158
    Quote Originally Posted by Cozz View Post
    Hi.
    Are you talking about switching it on and off?
    Thanks.
  9. #159
    Dec 2010
    Quote Originally Posted by gtmech View Post
    Ah Ha. This is truly a case in point for the old addage "you get what you pay for". In this particular case, however, "it's get nothing for what you didn't pay for".
    So what I can gather here is that it will comm. with newer Ford Pats5ish cars and not much else, right?
    Basically more things post-2007 perhaps?
    Guys, I'm just intrigued, again, not trying to be an a-hole.
  10. #160
    PierreTheron's Avatar
    Centurion,South Africa
    Default Sbb
    If you do an ecu replacement on
    Hyundai.
    You will be able to get pincode from vin.
    Can you match the secondhand ecu to this car with SBB.???
  11. #161
    Aug 2010
    hi
    for some Toyota older model u need to reflash or read dump from ( ecu or immobilizer ) and then program key using ZED BULL ,TANGO ...etc, u can not reset it using diagnostic device even the DEALER device .
  12. #162
    With the version 3.3, Can't access immo control unit on 1998 Grand cherokee. Result " ECU not found"
  13. #163
    Same my my V3.3 , i can't access Immobilizer control unit on 2000 NISSAN PATROL, result "ECU disconnected"
  14. #164
    DK Veteran Automat's Avatar
    Chuichu village, AZ
    Quote Originally Posted by lockbreaker View Post
    Works on every ford I've used it on so far, US market.
  15. #165
    DK Veteran canorivera's Avatar
    M?xico
    Quote Originally Posted by Automat View Post
    For me too, but in most of cases I need to use the erase keys method instead of adding keys.
    Love DK long time too...
    Don't forget the button
