Page 1 of 46 12345611 ... LastLast
Results 1 to 15 of 685
    ray-ray's Avatar
    Default sbb china report what is working
    version 31 and 32 what is working and what was added to version 32 that is missing in 31?so far gm basic and "can" are working,but i could not do a saab.the saab was a 2005 "97" it use a z keyway with a megmos 13. z keyway chip inside are 46 or 48 had to make these one.programing was done by (obp) sbb fail also had the same result with a toyota corolla
    2007 4d-67 .please keep posting your finds and add a jumper box to the battery for better connection.
    ray-ray's Avatar
    no go on a 08 hhr chev. tryied other cars would not connect.
    i got with v31 work on pontic g5 2007 worked .not comm with dodge,work on honda civic 07 so far, not tested on toyota and others yet.had problem connecting honda becuse of battery volt low ,work with jumper battery.tool allready paid it self by now.but it wont do fob on gm ,any other tool capable to do that?
    vw (gol 2008) gm (celta 2003) worked normal.
    ray-ray's Avatar
    06 ponitac g6 work tested.
    did any one manage to do golf 5 can with sbb ? and honda with sokymat chip ?
    electromech's Avatar
    Behind a large rock
    Does golf 5 without pin code
    ray-ray's Avatar
    keep posting it helps .i did a pats2 ford added a key (work).
    I tried my newly acquired V32 SBB and it worked on my 2009 Chrysler 300. I will try a 2008 Chrysler Caravan tomorrow but I assume it will work for all CAN Chryslers.
    D.
    ford (ecosport 2003) worked
    vw(golf 2002) worked,
    EU
    V32 work on
    ford transit EURO 2001
    ford Focus Euro 2002
  13. #13
    DK Veteran marginal's Avatar
    Question How much?
    Hello people.
    Could you, please tell me where you've bought the V32 from, and how much?
    Regards.
    I already bought 1, thank you :-).
    Est Modus in Rebus !!!
  14. #14
    worked on 2003 ford focus usa.program keys after ignition switch replacement
  15. #15
    ray-ray's Avatar
    mitz. eclipes 05 4d-61 it program with the pin code are ready there.(no need to imput)work tested.
