Results 1 to 2 of 2
    Post pin code by eprom
    i am loking software to read pin code by eproom , i going to buy xprog and upa, but i need some information, what software i will need to use with this tool, and where can i buy this tool, and need some information about eproom how is the processed to read eprom how find the pin code in eproom?
    obdmaster's Avatar
    Never never land
    Thumbs up
    Quote Originally Posted by dam495 View Post
    you are correct to buy xprog m8, as it can by-pass security and on some immo mcus there is security such as vw1 and opel 1. i use upa only for eeproms mostly as xprog seems to moan alot about bad connections on eeproms
    there is some hardware around also that can make transponder from dump such as tango, here is a link.
    TANGO TRANSPONDER PROGRAMMER - TRANSPONDER/KEY PROGRAMMING
    hope that helps m8
    You need every tool in the book, to do this auto locksmith job.
