I read that v.082010 Chinese clone kills Airbag block when you start scanning errors. Is this true?
nira (17th February, 2020)
Need help," Sorry, but a fatal error occured! Please contact developer!."When I test interface. What went wrong with op-com.
My op-com was work ok,early of the week,readed two car;Zafira 1.8 & 2.2 year 2002.And then suddenly ,on Feb 26,I have install Vag-com on the same machine.now Vag-com is work ok . but op-com does not work. I would appreciated if you guys could give me some advise how to solve this problem.Is there any chance to get it back to work .
Have a good one.
Peter
1. plug in the Op_Com interface into USB port
2. is it detected as Op-COM or is it detected as Ross-Tech? (you will find these info under: system / device manager)
atb
Pasta19881 (27th June, 2024)
use mprog to edit opcom interface eeprom
http://www.ftdichip.com/Resources/Ut...s/MProg3.5.zip
use attached template
nira (17th February, 2020), Pasta19881 (27th June, 2024)
sorry forget to quote...its related to the entry from tk500 and
manocao
because it detects no original hardware but clone
at least it doesnt kill the interface
what do you mean with doesn't work. i think you tried to generate a valid license with the copy request code to repsponse code method, or am i wrong? i you do so the license.dat is invalid and the eculist and other files cannot be decrypted. the decrypt method is completly different from the old 100315 version. for the 100315 version i know how to decrypt the files but for the new 2011 version its not possible that way. they use rc4 algo to decrypt and then decompress it and this seems to be in relation with the lic file.
how to precede with Mprog.
1. plug the interface (Op_Com) in to USB
2. run Mprog.exe
3. go to under MProg/Tools and push "Read and Parse"
4. go to under MProg /File and push "Open" - open the file provided above
5. go to under MProg/ Device and push "Program"
6. look into below window of the "MProg" - "successful programed one device"
7. unplug from USB port the cable
8. plug again into USB port the cable - now it will show you the message "OP-COM Interface V2"
That's all.
push thanks!
dolnicar101 (26th July, 2016), j0anita (31st March, 2017), nira (17th February, 2020)
Any news, about this year Opcom version?
I mean, a working clone . .![]()
Hi!
Does it also reprogram the clone with MPROG?
Is it the same as the OP-COM Advance?
Is there a German software?
MPROG is used to repair the clone after corruption when trying to use the new original version software
You need "MProg" to fix problem related to driver compatibility - if the uC is empty you need to re-flash with external programmer. (ICD2, ICD3 etc)
atb
Are there any news for OP-Com for china?
What is the latest Version vor FW 1.39?
I`ll be happy for a download-link
THX
