Page 1 of 4 1234 LastLast
Results 1 to 15 of 53
    Junior Member 111tech's Avatar
    Belgium
    Default Trouble installing VIDA
    Hi m8
    I am having enormouse trouble installing vida 2010A, the moment it displays "installing windowsinstaller31" i get a message saying "Can not start SQL-Browser" and can go further.
    An help is appreciated.
    Top Poster + Iroll's Avatar
    Default Hi,
    Uninstall all versions of SQL Server.
    VIDA will install SQL Server 2005.
    Belgium
    Quote Originally Posted by Iroll View Post
    ok i will try it right now, thanks
    Belgium
    I did remove all SQL and restarted the laptop (lenovo T61 with XP SP3) after trying to install vida gettin message right after " windowsinstaller31"
    " Error number: 0x80004005
    Description: [Micrisoft][ODBC SQL Driver][DBMSLPCN] SQL Server does not exist or acces denied
    setup will now terminate"
    Default Hi,
    Belgium
    Thanks mate, i will try it right now.
    I appreciate the help
    Belgium
    Hi i did point for point what Iroll wrote, but no luck.
    see attachment.
    Default Hi,
    Confusing!
    Default Hi,
    What caused my conflict?
    I tried to install VIDA with Visual Basics 2008 already installed which also installs SQL 2008. It was a pain to get Visual Basics software to uninstall. I was able to reinstall VB after VIDA install.
    Belgium
    hope this time it will work
    civino
    Guest
    111 tech
    You must install vida only on Part c:\
    on all other parts you will have many problems. I have had the same shid and now on Part c:\ its works super.
    sorry for my english, I`m from germany.
    Default 2010A-2010B Computer Settings Changes
    ?Perform Computer Settings? popup changes!
  13. #13
    Well I have that exact same tab. I just cant figure out how to connect to my DiCE. Under the diagnostics tab the image on the left is not showing up. I believe that is what I am supposed to click to get this working. Any ideas. I will take a screen shot on monday for you to show you what I am looking at. I might just have to reformat this computer since its getting old anyways.
  14. #14
    Belgium
    Hi guy's
    Spend the whole weekend trying to install, but no luck. Did everything explaned above but it could not install MSXML 6.0 and it stopt, even do i de installed it before.
    Start with a virging computer is not an option cause there are to many programmes installed.
    Hope you can help.
    Grtz
    Oh yes i am installing it on drive C.
  15. #15
    Which programs do you have installed? I know that BMW ETK can not be installled or Vida will never install. Send us your list of programs and maybe that will shed some light.
