Are you using Enigma1 settings ? What channel list are you using ?
Hi Bulld0g, yes I have done a reboot and have selected in the Blue Panel Common Interface as that is the only default cam there... is that the emu you refer to, if not how would I go about selecting this,
I still have no listing in the bouequets and still only the FTA staions work, its driving me mad now
Ok i take it you are c/s to get your channels ? we don't talk about c/s on here but you need to download CCcam from the server from within your image, install it and ftp your config file to the box and select CCcam as default cam
i have a migraine from this dreambox! i will try to correspond over the weekend... thanks for all the help
Hi Bulld0g, I have downloaded The Gemini2 Project from the net and have sent it via FTP to my box, I rebooted the box and still no bouquets have been added, do i need to add the file again? When I go into the Blue Panel the only option I still have is the Common Interface, do you know where I am going wrong please?
Hi Zaf, I am using a DM500V8 box, my box was working fine until a few days ago when the stations never came on, I did a factory reset but this got rid of the bouquets and got rid of desi-sensation which was in the Blue Panel, now all that is working on the box is the FTA stations and in the Blue Panel now I only have the option to choose Common Interface as the default Cam and when I go to Set New Cam it is the same option there, I no longer have the desi-sensation option which I have been using, but I am guessing this is different from who you purcase your box from and there is no bouquets listing now either,
With Bulld0gs help I managed to FTP a new set of boquetes which I download from this site to the box as you have seen from this thread, I rebooted the box and restated enigma bit the listing is still not showing up, I then sent CCcam 2.1.4 - The Gemini2 Project via the FTP to the box which I downloaded from the net in the hope that this will help get the boquetes listed and the stations to work, I rebooted again but still no job and I still only have the Common Interface in the Blue Panel, Im pretty much stuck now and have no idea on how I can get it to work again,
Can you offer me any help please?
Hi Zaf, not tto sure on how to find that out but when I choose Automatic Transponder Scan have the Gemini Project picture in the background, is this what you meant or do you mean when I switch the box on, if this is the case its a bluescreen with GP on it, which I'm guessing is for Gemini Project
