Results 1 to 5 of 5
    Senior Member el_futte's Avatar
    denmark
    Default help altea 1.9 wont start after tuning
    i have a guy there have try 2 tune his altea 1.9PD 105hp
    afther the read out he sent the file to a tuner
    and flash the ecu . now the car cant start.
    he tryed to put the old file in but nothings works whit the
    he have use a AVDI PC USB Interface
    the ecu is a bosch 0 281 013 282 edc16u34
    ipejasinovic's Avatar
    Jun 2009
    Bosnia & Herzegovina
    For that sort of things, you should use Flasher, not Diagnostic tool! Now, you probably locked ecu with wrong writing or wrong checksum.
    Galletto 2012 v54 full with JTAG and Mini available
    Big Stars never dies:
    Colin McRae (1968 ***8211; 2007)
    Richard Burns (1971 ***8211; 2005)
    Georg Plasa (1960 - 2011
    denmark
    yes it is not i there have done the tuning here . im just try 2 help him.
    but yes somthing is very bad whit this cabel here.
    Europe
    looks like BDM will solve this problem ...
    DK Veteran rappttor's Avatar
    PERPETUUM MOBILE
    can you log on to the ecu with vcds?do you have any dtc on the engine and IC or immo module?
    i had a similar problme with an O2 face lift, same ecu...the soft was ok, but it didnt start anymore...
    give all the details about the car and engine....
