Results 1 to 15 of 17
    Mar 2009
    Default ???MB ir Key the definitive guide???
    Hello Guys.
    I have a customer whose IR key from a w202 is damaged(WATer).I have been going through all the threads here and cant seem to find a solution.What is the procedure to get this car back on the road and what tools do I need to buy,I know that I will need x-prog.I have bought a second hand key,what else do I need.Any help in the right direction will be appreciated.
    Mar 2009
    Does anybody use this?
    Not a problem mate, change the eeprom in the old and put in the new
    Mar 2009
    I have done this but it still does not start.
    read the data frome the 2 mcu in your EIS
    and the esl data
    with x prog and send the data to me
    Fallen's Avatar
    I repaired a IR Merc flip key a while back.
    Buttons had come unsoldered and the customer had put the batteries in wrong.
    You can check if it is transmitting by looking at the LED through your camera phone, if it's working it will glow purple when you press the button.
    I had to re-sync it with the car by holding down the button, lock then unlock the car with the blade, then start the car. All with the button held down.
    Mar 2009
    Thanks for the help guys.Fallen the w202 that I am working on is the last Version,it is NOT a flip key and it uses the same key as the w203
    Mar 2009
    About the pdf that I uploaded .Does anybody have this and is it recommended
    Go for original MB keyprog2 from www.noimmo.lt, you'll not regret it. I've used AK series from China and MB keyprog2 original from them and I can tell you when come to Mercedes IR key making don't go for China tools as totally no support at all. The ESL tools came together with the MB keyprog2 save you a lot of work when compare to china tools, their support is good. The only thing to take note is maybe you'll need to get other tools to complete your Mercedes IR key making like Xprog-M to read the dump from EIS and ECU. Somemore they support the making of ir keys for the newer series of car just by calculation of the dump from your eis.
    Quote Originally Posted by sogaro View Post
    this should work if it was just water on key
    swap the mcu (not eeprom there)
    Mar 2009
    Yip.I swapped the nec's still no good.
    I wanted to ask experienced users of the noimmo tool for mercedes ir key programming if there is something to be aware of , before i buy from them the tool . What i mean is if the client after i do a key for him, he orders a key from dealer too, will it work ?His exhsisting keys will stll work ? Also the ESL and ECU can be done via diagnostic socket or they also need to be removed from vehicle for eeprom reading and editing ?
    locks85
  13. #13
    If like they say it generates keys from just EIS dump then you have nothing to be afraid of as old and dealer keys should still work. I know this is possible though using Benz Commander by Abritus
  14. #14
    are you Sire abritus can calc the hashes? I cannot find anything about that on the abritus site.
  15. #15
    That info is from Miro though not tried it yet
