Results 1 to 15 of 20
    Sep 2010
    Default help getting keyedit
    I follow below but cant get the key edit up when pressing 8989 where do i check the auto update this really doing my head in as I have paid 200 for 5 channels
    please can someone help me I have put the lastest carlin and grooverider on
    really need help here
    Once the scan has finished go to menu then highlight accessory and on the remote press the numbers "8989" you will then see
    "keyedit" appear on the right hand side, go to it and press ok and just check that auto update is on if its off just turn it on.
    then go to to your channels by exiting the menu and pressing ok.. Select a non FTA channel and leave it until a picture appears
    PLEASE NOTE IT CAN TAKE UP TO 5 MINUTES TO UPDATE
    Jul 2008
    Default hd combo
    you also need to go to network and turn it on then go down to csnet press ok and turn it to ustream then exit and it will take a few seconds for it to say connected,once it is connected go to sky sports 1 for 5 minutes then that will be it.
    Jul 2008
    Default hd combo
    make sure you are pointing the remote at the box after the scan when you press 8989 and it will come on,ps you dont need to go into keyedit as it is always turned on you only need to turn the network on then go into network and go down to csnet press ok it needs to be on ustream then exit it will say saving data.exit till you see a picture and go to sky sports1 for 5 mins and thats it all done.
    Sep 2010
    thanks mate but how do i get ustream on when i go into network i turn it on then the ip addresses are filled in the one below this i can type an address in in the home stream server and i type ustream in but have no idea what this does?
    really getting to me now
    DK Veteran psats's Avatar
    Sep 2008
    Quote Originally Posted by smiffy123 View Post
    its not in ip setup
    go down to net applications.
    Sep 2010
    where is cs net
    Sep 2010
    sorry if im being thick but wheres net applications ive gone through it all but cant see it
    smoggy's Avatar
    Apr 2009
    UK North East
    from the remote select menu/options/network/net application/type/select Ustream
    Sep 2010
    thanks does this show after you have done the 8989 and is there any reason why this is not working for me
    smoggy's Avatar
    Apr 2009
    UK North East
    I don't have the box so can't answer for sure but generally the keycode options etc. only become available when the box is flashed with correct firmware, so maybe you haven't flashed it correctly.
    amber nectar calls...good luck
    Sep 2010
    any idea which is the correct firmware for this hd +combo with lan as I can only get access to the main 5 channels and cant access through when im pressing 8989 im in coventry can i get the scrambled channels i have a sky dish and vm cable?
    Jul 2008
    Default hd combo
    you need to flash it with grooverider hd combo+ 1214.uad first then flash it with the latest software carling+ 0712.uad.After this do a full scan,then when you have done this go to accessory and press 8989 and you will see key edit come above network.Go into network and turn it on then you will see cs net at the bottom,go into that and turn it to ustream and exit.go to sky sports1 for 5 mins and that is it.
  13. #13
    Sep 2010
    just to check im flashing it properly. I load onto the usb stick when i get this up on starview I am pressing green button which saves the file and opens up another document. When i click ok to this one i save all and the system reboots is this right?
  14. #14
    Jul 2008
    Default hd combo
    just press ok and thats it
  15. #15
    Sep 2010
    when i press ok nothing happens i need to press the green button for something to happen am i loading it onto the usb stick wrong then?
