Results 1 to 15 of 22
Thread: upa help
    Top Poster ionut_mtb's Avatar
    romania
    Default upa help
    hello. i have a problem with the upa usb programmer. i try to read an mc9sdg128e but no success. vdd/vcc out of range, 1 error found device mc....., at connection pin 9 vdd 11.42v Bad. The upa is recognized by the software. the connections are made like in pdf. strange is that one week ago i was reading an mcu with success, and after a day tring the same mcu with same connections and soldering and fail reading... same problem pin 9 vdd Bad..
    russia
    Give a connection photo
    Quote Originally Posted by ionut_mtb View Post
    HELLO
    that is this ,it is a dasboard?cas?or other
    maybe it is securised!!!
    romania
    i had used the connections like in uuprog pdf, with p9 lifted, also tried with pin6 lifted but no success, 2 different cables, and i verrified with multimeter the connections... problem i think it is with the programmer...
  5. The Following User Says Thank You to ionut_mtb For This Useful Post:
    capi (11th May, 2014)
    romania
    this is an airbag module..
    hello
    it is original upa or clone
    try to read the simple eeprom
    Default immo golf3 of10v
    Hello can anybody give connection pdf how to read eeprom of10v of golf3 with upa-usb
    Essex
    i think this is common problem , i have quite a few programmers and my upa ig genuine but i find it hard using it as the settings for each chip are so different . ive managed to read tms and hco5 ok but anything else i dont bother as cant seem to get settings right , maybe there is something somebody can share to show connection settings and i dont mean the pin settings that i already have. i mean what voltage setting for that chip ect ect.
  10. #9
    Slovenia
    Hi all,
    Are you runnig airbag module on power supply? "Pin 9 vdd 11.42v Bad" - the voltage is way too high as upa can only deliver 5 volts (usb). It's also too high for motorola...
    Hope it helps,
    Smac_a
  11. #10
    rj22's Avatar
    The AIR 0 285 001 249 is CR16
  12. #11
    romania
    i'm using only the usb voltage, and if i power upa separatly i have almost same voltage..on P9
  13. #12
    romania
    @newgeniehex
    i dont know if it is a clone, what eprom you say i must read? the airbag module has procesor, not eprom...
  14. #13
    Slovenia
    Can you post some pictures (will be a lot easier). Although if there is motorola on pcb there is a good chance that dump you are looking for is stored there...
  15. #14
    romania
    not so good pictures...
  16. The Following User Says Thank You to ionut_mtb For This Useful Post:
  17. #15
    romania
    picture in upa soft
  18. The Following User Says Thank You to ionut_mtb For This Useful Post:
