Results 1 to 3 of 3
    Top Poster + junger's Avatar
    Jul 2008
    Default bt home hub2 ip setting problem
    Hi All
    Using a drembox 800hd with a bt homehub2, when in the network test i get
    DHCP disabled
    ip address unconfirmed
    name server unconfirmed
    any ideas why
    thaNKS JUNGER
    V.I.P. Member wilf's Avatar
    Jan 2009
    uk
    i would suspect you have the settings wrong in network? unless you are setting up static ip in box, you should leave it set for use interface....yes and use dhcp....yes
    Jul 2008
    Quote Originally Posted by wilf View Post
    Sorted, thanks, the router gateway was incorrect, bt home hub, what a load of sh**e
