Page 1 of 23 12345611 ... LastLast
Results 1 to 15 of 334
    Default Remove FAP on Marelli 1.3 MultiJet 75/90hp
    I see lots of posts about FAP removing for 1.3mjet Marelli ECUs, I see many people say "there's a sw" or "it can be done" or "I do" but I see nobody says how to get informations about.
    Can somebody explain how people who remove FAP operate on Marelli ECUs as the unique sw for DPF/FAP is EcuSafe and it does'nt do anything on Marellis?
    Thanks a lot
    May 2009
    Belgrade
    You are right. Ecusafe not work with 1.3mjet Marelli flash. What can we do? Any other sw?
    Nobody ?
    ipejasinovic's Avatar
    Jun 2009
    Bosnia & Herzegovina
    Next week, probably, we will know something more.
    Galletto 2012 v54 full with JTAG and Mini available
    Big Stars never dies:
    Colin McRae (1968 ***8211; 2007)
    Richard Burns (1971 ***8211; 2005)
    Georg Plasa (1960 - 2011
    Quote Originally Posted by ipejasinovic View Post
    Keep me informed because I'm interested
    jolidj's Avatar
    ITALY
    You open the ecu....i dont now were is the file correct.
    Quote Originally Posted by jolidj View Post
    Joli Joli per forza apri la Ecu... ma per Marelli non esiste ancora un sw in grado di individuare tutte le gestioni e le soglie di intervento del FAP.
    Teo
    jolidj's Avatar
    ITALY
    Exsist the sw but i dont have it.
    per poco tempo
    for short time
    jolidj's Avatar
    ITALY
    anather image
  10. The Following User Says Thank You to jolidj For This Useful Post:
    kuzeyli (14th March, 2016)
  11. #10
    It seems with last archive EcuSafe makes also 1.3mjet... did somebocy try? File after deFAP is really strange.
  12. #11
    rossoelab's Avatar
    Italia
    Quote Originally Posted by teoturo View Post
    ciao
    ho capito bene teoturo?.....ecusafe ora pu? disabilitare il dpf sui marelli???? ho un cliente con dobl? 1.3mj a cui devo eliminare il dpf. avevo aperto anche un post tempo fa.
    mi puoi aiutare?
    grazie!
    hello
    I understand teoturo ?..... ecusafe can now disable the dpf on marelli?? I have a client with Dobl? 1.3mj that I have to delete the dpf. I also opened a post long ago.
    can you help me?
    thanks!
  13. #12
    rossoelab's Avatar
    Italia
    da quello che si dice effettivamente la versione 1.9.3.1 ha protocollo 1.3mj ma ancora non funziona bene
    from what it actually says the version 1.9.3.1 has 1.3mj protocol but still not working properly
  14. #13
    kugglefischer's Avatar
    In an Ecu
    Question
    no!!!
    it dosnt work.............with any version of ecusafe.......
    any input will be appreciated,
    K
    The difference between men and boyz...Is the price of there Toyz.
    LEACHERS.....DONT KEEP ASKING FOR PASSWORDS
    DONT FORGET TO PRESS THE THANK YOU BUTTON IF MY WORK HELPED YOU....
  15. #14
    Moon
    if anyone can provide a damos for this ecu I will try to do it manually. I also need to do this for a fiat doblo 1.3
  16. #15
    May 2009
    Belgrade
    There are originals
  17. The Following 4 Users Say Thank You to banetv For This Useful Post:
    cole_mcs (18th April, 2016), dule14786 (25th September, 2019), ibmok (5th September, 2019), mcday (29th October, 2014)
