some movie ones can remember all because it says service removed![]()
Sorry to ask but are the files the same for both dm800hd and dm500?
Junger
when i open the interactive channels such as the sky sports actives, the channel name automatically get renamed..
What can i do to prevent this from happening?
Using you're excellent bouquet, but when i try to go on FX HD it says SID not found in PAT
Also ITV 3 and 4 HD both have there names changed to 4 digit numbers instead.
Any ideas on how to sort this please.
Cheers
fxhd doenst start till 7pm
give it a try then
FX HD programmes don't start until 7pm
ITV 3 HD & ITV 4 HD are testing off the EPG at the moment they will change to numbers until the 15th November and they will stay as there there proper channel names
Here is the latest update
DreamboxEdit 4.0.1.0 Used (Recommended) Guide Here
Updates: 10th November 2010
DM800 Bouquet Only
Climax3 Renamed To Extreme
Discovery Knowledge Renamed to Discovery History
Discovery Knowledge +1 Renamed to Discovery History +1
Max TV Renamed To Olive TV
Sky Box Office (Frequency Changes)
Removed Channels
None
Picons
Updated new channels
** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
Code:Also added Picons for Sky UK (Base set from Picon4U) and the rest updated by myself Use any FTP client, DCC for example, to transfer the picon directory to one of the following paths on Flash, HDD, CF or USB respectively: /usr/share/enigma2 NOT recommended, because of limited capacity of the flash memory /media/hdd HDD will keep running indefinitely and may affect image performance /media/cf Recommended if CF available and successfully mounted (8000/800) /media/usb Recommended if USB available and successfully mounted (8000/800) Picon will display immediately on zapping, no further setup required! Always remove old picons from Dreambox before uploading new ones, Sometimes they don't overwrite correctly
Please keep this thread clean, Use the Thanks button rather than posting on the thread
Ok i know there is a simple answer to this, but i have spent hours searching and i know its stareing me in the face and i cant see it,
How do i connect my dreambox to my mac to install these bouquets, ie what cables do i need ?
Thanks in advance
MEGAUPLOAD - The leading online storage and file delivery service THINK THIS is for mac users
Thanks for the reply, i have that program already,sorry i didnt make myself clear what i would like to know is how do i connect my dreambox to my pc so i can copy these bouquets to my dreambox, do i need a ehternet cable or a rs232 cable for example ?
ehternet m8 .. u are connected to your router anyway ,. go into options and put dreamox ip in and root and pass word dreambox and send
