Here is the latest update
DreamboxEdit 4.0.0.0 Used (Recommended) Guide Here
Updates: 31st October 2010
DM800 Bouquet Only
ITV3 HD (New Channel)
ITV4 HD (New Channel)
Sky Box Office (4 Channels, Frequency Changes)
Removed Channels
None
Picons
Updating nearly 50 picons too better ones and nearly fully updated Channels (Except Adult)
** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
Also added Picons for Sky UK (Base set from Picon4U) and the rest updated by myself
Use any FTP client, DCC for example, to transfer the picon directory
to one of the following paths on Flash, HDD, CF or USB respectively:
/usr/share/enigma2
NOT recommended, because of limited capacity of the flash memory
/media/hdd
HDD will keep running indefinitely and may affect image performance
/media/cf
Recommended if CF available and successfully mounted (8000/800)
/media/usb
Recommended if USB available and successfully mounted (8000/800)
Picon will display immediately on zapping, no further setup required!
Always remove old picons from Dreambox before uploading new ones, Sometimes they don't overwrite correctly
Please keep this thread clean, Use the Thanks button rather than posting on the thread
