Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
  1. #16
    DK Veteran dimitar22's Avatar
    Jan 2009
    Quote Originally Posted by ottomotto View Post
    I have SDP3 2.6 running locked to yellow USB key from autokg. Anyone knows how to emulate it?
    Use this proccedure
    http://rapidshare.com/files/64394078...-EDGE.rar.html
    INSTALLATION INSTRUCTIONS
    1. Unzip and Unrar.
    2. Make sure you have the latest Sentinel dongle drivers installed.
    3. To dump and solve make sure the original Sentinel key is connected
    to a LPT or USB port then Run EDGESPRO.EXE in the EDGE dir.
    4. Select the Sentinel tab, choose a filename for the result .dng
    file, and press "Dump&Solve".
    This can take some minutes depending on what type and how many
    algorithms needs to be recovered.
    The "Specify Developer Id" and "Specify Write Password" options
    are for advanced users, and not required.
    "Specify Developer Id" allows you to dump and solve from emulators
    without physical dongle.
    "Specify Write Password" allows you to dump faster, if you know
    cell 4 (write password).
    5 Now run SENTEMUL2007.EXE and press "INSTALL" button and if installation
    was successful driver status window will be changed to:
    "Status : driver is installed".
    6. Now you need to open "Emulator" tab, Then you press "Start Service"
    button. If everything is ok you'll see "SENTINEL Emulator Service
    is running"
    7. Open "DONGLES" tab and press the "Load dump" button, then navigate
    to the .dng file you created with EDGESPRO.EXE[/QUOTE]
  2. #17
    Jan 2009
    And if it is succesful please share the dng file with us.
  3. #18
    Quote Originally Posted by dimitar22 View Post
    Does not work. I think it is other type USB key. I used to have original Scania USB key some time ago and it look different from this one.
  4. #19
    Jan 2009
    If it is this kind of stick i think that nothing can be done
  5. #20
    No it is different - I don't even know what kind of stick it is.
  6. #21
    Jan 2009
    Hello if any one has the original dongle please use this dumper and you should get 3 files send the files to me i have friend who can help in making this software work without dongle.
  7. #22
    Default Convert .bin to .dng file.
    Can you make .dng file ?
    Regards.
  8. #23
    Jun 2017
    Hi, I have access to orignal usb cellar, is this procedure still valid?
    Please, disciple my English, I'm using google translate.
    :apertar as m?os:
