Results 1 to 10 of 10
    w.yorkshire
    Default FORD IDS V67 RELEASE DATE QUESTION?
    hi all, i have just received ids v67 clone and module programming says "selection not available" i think i may need to reinstall windows and ids after changing date in bios and windows. this is no problem but can anyone tell me the date i should set pc to if installing v67. i have searched for v67 release date but not found it so can anyone help. thanks steve
    w.yorkshire
    decided 2010.5 means may so set dates to june (wifes birthday) and functions are available. mods feel free to close if you wish, thanks steve
    w.yorkshire
    hi again, so now i have programming by setting date to 16 june will it stop working in a set time? can i avoid by changing pc times once a month? does using programming feature stop it? at worst could i just reinstall every tme it stops and use forever? thanks steve
    Czech Republic
    Quote Originally Posted by digi-dash View Post
    There is possibility how to change expiration time. Send me c:\Program Files\Ford Motor Company\IDS\XMLFiles\71863.tml
    and I prepare modified version for you.
    w.yorkshire
    thanks, can you pm me your email address, thanks steve
    DK Veteran RSwire's Avatar
    your girlfriends house
    Just copy it and make an rar and post it here. And does this "crack" work? If so alot of people could use it, so please share if it is a "generic" crack, not based on pcid.
    A DAY YOU DIDN'T LEARN SOMTHING NEW IS A WASTED DAY.
    Please don't pm me for keys, that is what the forum is for.
    If it helped, please use the thanks button, if thanks isn't enough use the scales.
    Czech Republic
    Quote Originally Posted by RSwire View Post
    It is generic, I post it modified back. I described it for another version in this thread http://www.digital-kaos.co.uk/forums...ramming-66388/
    Default FORD IDS V68
    Please modify the file for IDS V68.
    I used the crack(what setback the date at IDS starting) and some softwares(Esitronic,VCDS) are locked now.
    Thank you.
    Czech Republic
    here is modified file for version 68.
    there is fix for v80 yet?
