Hi, thanks for what looks like a great image. Can anyone give me a guide on how to install CCCAM into this image? Many thanks.
I just flashed a 500-S box with it - how do I get it from PAL to NTSC video setting.
The screen is rolling and I can't see the menu items.
I think I've tried every key combination there is - but can't find the video settings page :-)
[MENU] > [4] > [1] > [DOWN] > [RIGHT/LEFT]
no pal to ntsc setting, try changing the videooutput and format settings.
VIDEO SETTINGS
<- back
-----------------TV SCART-----------------------
VideoOutput CVBS / RGB+CVBS / S-VIDEO / YUV+VBS
Format autodetect / 4:3(LB) / 4:3(LPS) / 16:9
Background pictureformat (sets Aspect Ratio for radio mode image etc.)
-----------------VCR SCART----------------------
Switch SCART automatically on / off
this is home from home what a great image
could someone help me set up my motor as i'm stuck its a bit different to the other images
i've uploaded the satelites but not sure how to set up the motor at the moment i'm watching free to air sky 28 degrees
you just need assign each sat in the sat list to the correct stored sat number for your motor.
eg. if the motors default built-in sat table has 28.2E stored in postition 18, then setting 18 as Astra 28.2E motor setting would drive dish to 28.2E when you attempt to view a channel on astra 28.2e
goto:
>service
>service scan
>motor settings
assign stored motor setting number to the correct one for each sat in list, ie. the 18th stored position in the default built-in sat table on a tm-2300 motor may be at number 18 for 28.2E
manual motor setup then enables you step east/west to fine tune.
yes, would be easy to take all the fun and achievment out of setting up your motor system by adding usals like most other images but what is the point in that? just pressing a "scan all sats" button sounds like the most boring 1 second of my life.
Square wheels ,wotever next Ha Ha ............Paul
PAUL
