Results 1 to 14 of 14
    DK Veteran hercamp's Avatar
    Talking FLASH PROGRAMING PROCEDURE IN CAT ET
    ELECTRONIC TECHNICIAN (ET) TROUBLESHOOTING - Continued
    SYMPTOM
    Flash Programming
    This is a method of programming or updating the flash file in an engine's Electronic Control Module (ECM). Use
    this procedure if original ECM flash files are missing or not available. To update configuration files, Caterpillar Electronic Technician (ET) is used to flash program a file into the memory of the
    engine's ECM. If you do not have the flash file, it must be obtained from your Caterpillar dealer.
    MALFUNCTION
    Personality Module Mismatch. ECM has an incorrect or outdated Flash File.
    CORRECTIVE ACTION
    STEP 1.
    On EMCP, set ENGINE CONTROL switch to OFF/RESET. Set Battery
    Disconnect Switch to OFF. Set DEAD CRANK SWITCH to OFF.
    STEP 2.
    Connect the Cat ET to connector CDC-P7
    STEP 3.
    Set Battery Disconnect Switch to ON. Set DEAD CRANK SWITCH to NORMAL.
    On EMCP set ENGINE CONTROL switch to COOL DOWN/STOP.
    STEP 4.
    Establish communication between Cat ET and the engine's ECM.
    STEP 5.
    Select WinFlash from the Utilities menu on Cat ET.
    NOTE
    If WinFlash will not communicate with the ECM, refer to Troubleshooting, Electronic Service Tool
    Will Not Communicate with ECM.
    STEP 6.
    Program the flash file into the ECM.
    a. Select the engine ECM under the Detected ECMs.
    b. Press the Browse button in order to select the name of the flash file that will
    be programmed into the ECM.
    NOTE
    The Flash Files are located on a CD provided with the Cat ET software.
    c.
    When the correct flash file is selected, press the Open button.
    d. Verify that the File Values match the application. If the File Values do not
    match the application, obtain the correct flash file.
    e. When the correct flash file is selected, press the Begin Flash button.
    f.
    Cat ET will indicate when flash programming has been successfully
    completed.
    STEP 7.
    Turn the ENGINE CONTROL switch to MANUAL START. Check for proper
    operation. Repair any active diagnostic or event codes.
    WinFlash Error Messages
    If you receive any error messages during flash programming, click on the Cancel button in order to stop the
    process. Access the information about the ECM Summary under the Information menu. Make sure that you are
    flashing the correct file for your engine.
    I HOPE THAT HELP YOU
    if not just lost time reading
  2. The Following 3 Users Say Thank You to hercamp For This Useful Post:
    dupisa (24th March, 2022), je69 (5th December, 2015)
  3. #2
    Quote Originally Posted by hercamp View Post
    SYMPTOM
    Ok... so that has happened... winflash can't see the ecm anymore... what now?
    if cant connect after downloading error. close ignition twice and try to program from new ecm option.
    if not will need to see if exist a bench with extra conection data .
  5. The Following User Says Thank You to hercamp For This Useful Post:
  6. #4
    Member lituzz's Avatar
    At Home
    flash file for EMCP3.2??
    SOME PEOPLE SEE THINGS AS THEY ARE AND SAY WHY... I DREAM THINGS THAT NEVER WERE AND SAY.... WHY NOT????
    At Home
    Greetings, I have an EMCP3.2 controller on a genset, and I need to flash it. It has the following info:
    Part No.: 3007646-01
    S/N: 1648B059TA
    Software Part No.: 3222198-00
    Software Date: NOV2007
    Software Description: L1 6_0 Standard -- Spanish, 2.2 Prod, 7Nov2007
    Does this mean that the flash file I need is 3222198-00? If so, Can anybody share it? I have on my flash files: 3222197.FLS and 3222199.FLS
    Thank you all in advance.
  8. #6
    @home
    help me i need
    eng numb 191-4479
    power train numb 175-1171
    i need flash file
  9. #7
    @home
    ECM Part Number 1547443-05
    ECM Serial Number 0484D522ED
    Software Group Part Number 2456589-00
    Software Group Release Date JAN04
    Mon Sys Harness Code 23
    i need latest flash file of
    2456589
    please
  10. #8
    Feb 2012
    thkkkkkkkkkkkkkkkkkkkkk
  11. #9
    Aug 2012
    when u try to reflash with different flash file in win flash and it wont accept the file, change the interlock code to start with. Put passwords in and then reflas to the file you want then put in passwordsagain and thereyou go
  12. #10
    Top Poster khadang's Avatar
    Jul 2011
    hello all. please help me ho to flash for this ecm.
    ecm is blank
    thank so much advance!
  13. #11
    After flashing a 70 pins I get message "Unable to communicate with an ECM!
    It doesn't want to connect to either to et or winflash, please any more ideas or some other tricks to revive it?
    please help...
  14. #12
    I connect the the ECM to a cat comm adapter II using CDL protocol and it worked. Problem solved.
  15. The Following 2 Users Say Thank You to jackalfa For This Useful Post:
    mang5087 (2nd February, 2014), peko (15th March, 2022)
  16. #13
    peko's Avatar
    hi,
    can you explain what is CDL protocol ?
  17. #14
    Apr 2011
    Ecuador
    CDL
    Caterpillar Data Link
    caterpillar communication protocol to link between CAT products
