Page 7 of 13 FirstFirst ... 23456789101112 ... LastLast
Results 91 to 105 of 184
  1. #91
    norbisko's Avatar
    In a House
    I tried few cars,
    2004 Lexus- worked ok
    2008 Mercedes e350 - no communication at all (even OBDII function)
    2008 GMC Sierra- no communication at all (even OBDII function)
    2012 toyota camry- no communication at all (even OBDII function)
    2003 VW passat- very little
    In USA menu I have ; OBDII, GM, chrysler, Ford,
    I have updated the tool with newest software.
    Ther error message I get is no communication.
  2. The Following User Says Thank You to norbisko For This Useful Post:
    Automat (16th May, 2013)
  3. #92
    Very strange - with the MB I had no problems.
  4. #93
    diagnoza_auto2000's Avatar
    Sibiu
    Maiby his unit have problems.
    Tested and work good on Mercedes and VW cars too
  5. #94
    Just fyi: autel has annouced the maxidas ds808, so if someone is thinking about buying a maxidas, maybe it is worth waiting a bit.
  6. The Following User Says Thank You to paro44 For This Useful Post:
  7. #95
    DK Veteran marginal's Avatar
    Quote Originally Posted by paro44 View Post
    I quit waiting two years ago.
    Est Modus in Rebus !!!
  8. #96
    Mar 2011
    Default Try
    Quote Originally Posted by mulat View Post
    i bought the maxidas 708 but i didn trecived the software can you help
    This site always supply free software. Free Download Auto Diagnostic OBD2 scanner Software, Driver, Manual
  9. #97
    Mar 2011
    Default update problem
    Quote Originally Posted by keenius View Post
    There is some problems. updates program stop working about 3 days ago.
    Maybe coming some new cars or something.
    I bought one Maxidas Ds708 from Autel Maxidas DS708 China Fault Code Reader on Sale . It can work with most car models, that's good. but fail to work with these cars: 2008 mercedes , 2008 gmc, 2003 vw passat, 2012 toyota
    Does anyone can do these cars?
  10. #98
    Nov 2010
    This week - worked with latest software available:
    2007 MB ML350 - worked fine
    2008 Honda Civic worked fine
    2003, 2004, 2005 Passat & Golf - worked fine
    2004 Honda Jazz - worked fine
    2009 BMW M3 - worked fine
    2007 Mazda 2 - worked fine
    2003 Toyota Yaris 2006 - worked fine
    1996 Honda Accord - worked fine!
    I haven`t see DS708 not communicating for with some car for a while !
    Last time was ~1.5 year a go Toyota Landcruiser 1998, but after few updated - its all sorted. I can scan this car now fine.
    Update your software or check your tester, something is not right!
  11. #99
    norbisko's Avatar
    In a House
    Guys thanks for replies and confirmation that it should work on these models. Looks like there is something wrong with the unit itself, as software is up to date.
  12. #100
    jebo's Avatar
    DURIAN CITY
    Default cable
    Quote Originally Posted by norbisko View Post
    hi,
    try to check the cable.
    maybe 1 or 2 wires broken.
    trace all pins with ohmeter from obd16 plug to db15.
    all obd16 pins should have connection to db15 pins.
  13. #101
    norbisko's Avatar
    In a House
    I checked the obd II plug, and looks like pin 5 has to connection to back of db15... and that's Can low isn't it ?
  14. #102
    jebo's Avatar
    DURIAN CITY
    pin 4= chassis ground 5= signal ground.
    both are ground.
    6=can hi 14=can low
  15. #103
    norbisko's Avatar
    In a House
    so I don't have signal ground, going thru the plug
  16. #104
    norbisko's Avatar
    In a House
    Guys with ds708 do you have connectivity thru pin 5 ? ( talking obd II plug only now )
  17. #105
    jebo's Avatar
    DURIAN CITY
    obd pin 5 to back or metal body of db15.
    metal body of db15 is also ground.
