Page 2 of 16 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 235
  1. #16
    DK Veteran gmatj's Avatar
    Heaven (is place on earth)
    Quote Originally Posted by PSAXSEVOLUTION View Post
    not working
    Quite True
  2. #17
    Quote Originally Posted by PremierD View Post
    4 posts mate ..NOT WORKING .... Screen shots ,explanations .. anything ... not working means diddly squat ...
    If I may
    "Copy your normal DAS shortcut them change it to Login3.bat
    C:\Programme\Cobra\DblDlm\Login3.bat PKW ##
    ## its for language"
    He means that login3.bat PKW ## (where ## is the lang.Def) does not work -
    You still get everything in English and not in XX Language
    (What kind of screenshot will be needed ??)
  3. #18
    Moderator
    PremierD's Avatar
    Jun 2009
    You may ...............
  4. #19
    I am glad .........
  5. #20
    Hi M8's
    I think the password is wrong, I can't unrar the video.
  6. #21
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by acascarla View Post
    Hi M8's
    (20.24 MB, 917 views)... 917 dowloads mate .. I think that you need to check again, Password is correct...
  7. #22
    Top Poster + v8 dave's Avatar
    Jun 2009
    Geordieland -> Portsmouth
    Many thanks for this, proved very useful
  8. #23
    BRASIL / SUL
    can someone tell where get the DVD in September 2010.clear if it is not against the rules
  9. #24
    Top Poster GSI2's Avatar
    Feb 2009
    moon
    Quote Originally Posted by mecadriano View Post
    Hi mecadriano
    Do you know Google?
    Ask that guy he knows a LOT
    and my guess is the first result will have what you want.
    GOOGLE MERCEDES DAS 09-2010 DOWNLOAD
    try it...
  10. #25
    I will post the screen shots soon but when I am trying to open the Sim mode from my desktop,,its does nothing...gets stuck there...
    Thanks for helping
  11. #26
    Quote Originally Posted by gmatj View Post
    If I may
    you are correct,this is my problem.
    I get around the languages,is got to do with C:Programme\DAS\Thesaur???only 002=English lang
    working on it....
  12. #27
    Quote Originally Posted by GSI2 View Post
    Hi DK users!
    I've taken a lot from DK so its time to give something in return.
    I made an video explaining how to install DAS & XENTRY 09-2010 following Zolookas text guide and tools.
    It was made on Virtual machine but you can do it same way on your laptop or desktop.
    Description of video:
    01? Install Partition Manager.
    02? Disable DVD drive so that you can get all letter for partitions correctly at first time.
    03? Make Partitions.
    04? Create account STAR.
    05? Enable DVD drive.
    06? Login using STAR account and prepare Install using Zolookas tools.
    07? Place DAS key.**
    08? Install DAS (long, long process just wait, even if you think its stuck just wait... )
    09? When you get the message Setup complete don't press the Finish button go back to
    Zolookas folder and run after_installation.bat, only then press the Finish button.
    10? Disable Automatic hotfix installation.
    11? Disable Online Update BG service
    12? Install Xentry & Activate
    Here you must be around the computer because you need to delete one file from folder
    F:\Programme\Xentry\bin Note that bin its an hidden folder so take precautions
    before you start installation of Xentry, go to folder options and make them visible
    so that you are able to delete the UserConfig.xml file once its created.
    If you fail to do this, installation will never end and gets stuck with message creating folders and icons.
    If it happens go to task manager and terminate process then repeat process of installation.
    You don't need to uninstall it just reinstall.
    Now the activation stuff, its 09-2010 and old xentry keys don't work...
    actually they work if you replace CommonLic.dll
    from folder C:\WINNT\zak\StarUtils\ when you try to activate StarUtilities with old key
    it will accept the key but Xentry will not work.
    When you star Xentry its gives
    same license error but the great Zolookas made an executable to fix that so
    you just need to execute xe09.exe and you have your Xentry working.
    13? COM port settings
    14? (NOT ON VIDEO)
    Go to folder C:\Programme\DAS\Bin\ and edit file cal.ini
    LOOK FOR LINE
    PLATFORM=PART_W
    EDIT TO
    PLATFORM=PART_D2
    Here is the file already edited cal.ini 09-2010
    15? Have Fun
    **You can ask DAS and Xentry key HERE
    Download Zolookas guide HERE
    Download Zolookas CommonLic.dll and xe09.exe HERE
    Download EASEUS Partition Manager Home Edition HERE
    Download Video attached password www.digital-kaos.co.uk
    Please Don't send PM's asking for links to download MB software I don't have any try
    HERE
    Thanks for your contribution , but really I have a problem with CommonLic.dll file found in the forum because it is not the same as shown in your video so please this one in order to complete my xentry installation.
    thanks again
  13. #28
    Oct 2010
    Good work. Thank you.
  14. #29
    Hi DK users!
    14? (NOT ON VIDEO)
    LOOK FOR LINE
    PLATFORM=PART_W
    EDIT TO
    PLATFORM=PART_D2
    15? Have Fun
    HERE
    please send me the exact CommonLic.dll file that you have used in the video demonstration (because it is not the same as posted in the forum
    thanks by advance
  15. #30
    Quote Originally Posted by abdelilah View Post
    thanks by advance
    If you search (did you ?) around the forum , you will find it.
