Page 4 of 16 FirstFirst 12345678914 ... LastLast
Results 46 to 60 of 235
  1. #46
    Thank you very much for the video, it is very helpfull
    I installed it fine without any error,
    once i try to connect to a vehicle i reach till the ( Devaloper license warning ) and thats it !!
    it hangs , i try to go forword ( F2) , ( Enter ) but it wont proceed to the next step !
    No error Messeges
    what am i doing wrong !!?
  2. #47
    May 2009
    hi
    how disable hot fix and update bg
    many thanks in the advance
    regards
  3. #48
    Run > Msconfig > Startup
    and remove HotFix
    Run > Services.msc
    Stop update bg service and make it disable instead of automatic
  4. #49
    Tajikistan
    Hi everyone... Please give me the password for DAS-09-2010.rar which is available on the first page... I have download it.. but it requires password ... What should I do? ..... dilshod_tv@mail.ru Thanks in advance !!!
  5. #50
    Please read the original post very clear of all.
  6. #51
    DK Veteran cocutanu's Avatar
    Jun 2009
    Quote Originally Posted by Dilik View Post
    pass is : www.digital-kaos.co.uk
  7. #52
    this is great thanks again
  8. #53
    Vietnam
    I install DAS and Xentry successfully.
    Does anyone have installation guide for EPC & WIS 09/2010 ? I downloaded EPC_0910_1of1_b1.iso and wis0910.nrg
  9. #54
    installation instructions you should find inside the dvd,..they are there from years,...but you can not install these updates,..you need base dvd's:
    epc net full set from 05.2010
    wis net full set from 07.2010
    and then update to present release!
    Good luck
  10. #55
    I have installed the 9/2010 twice
    without any errors and applied the fixes but when i try to connect to a car it keeps trying to connect but it does not connect the voltage of the multiplexer in the right corner is 14V and green circle some time is shown
    Multiplexer and cables are perfectly fine and working in my old laptop,
    I don't have Serial port in my new laptop i use ( USB TO RS232 ) cable , could it be possible that this is the couse of my problem ?
  11. #56
    DK Veteran the_riddler's Avatar
    Jun 2009
    In The Workshop Or At The Pc
    Quote Originally Posted by altajer View Post
    Yes very possible,
    i had no luck using Usb-Serial or Pcmcia card,
    but others have these above working fine...
    and as soon as i used laptop with real serial
    worked fine
    Still in the workshop.
    if this post was use full
    please press
    the thanks button
  12. #57
    The thread topic mentions DAS & Xentry (and some talk about WIS and EPC issues), which one did you have trouble with and if you were unable to connect with the car, you must have had some kind of an error message. Would you mind telling the details?
  13. #58
    DK Veteran gmatj's Avatar
    Heaven (is place on earth)
    It is worth checking your COM device.
    If your are using a USBtoHUB serial device with Prolific drivers you will most probably have problems.
    Try using a "real" com device , among the best ones being those with the Oxford chipset.
    Hope that will help
    G.
  14. #59
    Dear The_riddle
    thank you for the confirmation
    Dear DB_Member
    As i said no error pops up just remains connecting to vehicle in DAS off course
    Dear gmatj
    thank you for the advice , i will check it out and i will certinly get back and give the result.
  15. #60
    Dear The_riddle
    Dear DB_Member
    Dear gmatj
    One more thought, DB_member is also quite corect to ask which application you have trouble with connecting.
    Is it DAS or Xentry you are having trouble with ??
    What fixes have you applied ??
    It could be another problem as well ...
