    Aug 2010
    Default w203 pressure of the railpunp to high
    i have a problem with a DB W203 C220D Bj. 12/2004 HP 110 new version.
    The
    pressure of the railpunp is to high 446 kg/p by 810U/min and the injection volume is to slow 5,2 g ( normal is 9-14 g)
    We change the railsensor and the pressure regulator
    Also we change the
    quantitative controller.
    Also 2 injektors.
    Dose somenone know what is here the metter?
    Thnaks fore your help
    Frank
    tomtom0785's Avatar
    Austria
    also checked wirings from sensors to PCM?? is this correct? do you have 5V sensor Voltage??
    are there any fault codes stored??
    enjoy and have Fun
    Tom
    Default w203
    check coolant temperetur sensor
    1) reset all DTC
    2) do a drive test 10KM at lest/ speeds engine from 2000 to 4200 R/M in 3 gear
    3) check DTCs and report here.
    We will help you.
    Quote Originally Posted by JFR-Tuning View Post
    The
    Also we change the
    Also 2 injektors.
    Frank
    treo's Avatar
    R
    I think you must change presure regulator on common rail.
    THE ONLY COMPONENT THAT CAN CAUSE THE FAULT AFER YOU CHANGED PE FUEL PRESSURE SENZOR AN REGULATOR VALVE FROM THE RAIL IS ONLY THE FUEL PUMP (IT SI POSSIBLE THAT THE FLOW OF FUEL ON THE RETURN HOSE FROM THE HIGH PRESSURE PUMP IS TO HIGH)
    Citroen C4 user
    Citroen WRC fan, Citroen Maniac
  7. The Following User Says Thank You to marius.macave For This Useful Post:
    TR0UBLESH00TER (16th March, 2017)
