Results 1 to 14 of 14
    Aug 2010
    Default AM29BDD160 how read/write this flash?
    Guys, help me please! AM29BDD160 - whitch equipment are you using for read write this flash?
    I used Galletto and BDM 1255 - its not read/write this flash
    On Audi A6 2,7Tdi I didn't write, only read flash AM29BDD160
    On VW Crafter 2,5 Tdi I didn't write, only read flash AM29BDD160
    Help me!
    laserkill's Avatar
    you can read it with labtools or if you can building ezoflash you need to remove that.
    laserkill's Avatar
    you can read with labtool or if you can building ezoflash and you need to remove from ecu this AM29BDD160.
    Aug 2010
    thanks , but i want buy universal programmator for more useful flashes.
    How about OMEGA?
    For this ECU you better try with a BDM. No need to dessolder the flash...
    You can read/write/cheksum without problem !
    Aug 2010
    no! BDM 1255 NOT WRITE THIS ECU! I tried wrote! not possible!
    Oct 2010
    it's spansion memory??
    Quote Originally Posted by metric View Post
    Try with a real BDM tool !
    I can make. CMD Flasher.
    Aug 2010
    CMD flasher, BDM 1255 only read this flash, not write!
    Aug 2010
    yas200979, can you write flash AM29BDD160 on VW Crafter 2.5 TDi? (если прочитаешь, то приедем завтра в Глубокое)
    Seems the same topic of yours in the other subforum has been left unattened. I am not a BDM 1255 user but what did your tool say when not write. The one possibility of not write is hardware protected, this can be checked and correct.
  13. #13
    Aug 2010
    Zmann, +1!
    You are right! Today problem solved!
  14. #14
    italy
    Default spansion
    come hai risolto
    help solution pleas
    tanks
