Results 1 to 15 of 15
    Top Poster pinky1970's Avatar
    Jun 2010
    Tenerife
    Default Ml320 goes into limp mode
    Ml320 sometimes goes into limp mode and misfires when i start and put under load up hill, getting ideas, i have just changed the plugs.
    Tacho Pro 2008
    Sep 2009
    Start by having the fault codes read and then post them.
    Jun 2010
    Tenerife
    Fault code showing, different banks and diferent cylinders, it not the same cylinder or same bank, otherwise i would think the coil pack. cant remeber the code number.
    Tacho Pro 2008
    DK Veteran trigital's Avatar
    Aug 2009
    Change fuel filter.
    Mar 2009
    Check the map sensor
    Default re
    try to clean the throttle valve, and clear adaptation.
    DK Veteran Albanais's Avatar
    Feb 2010
    Tirana
    Quote Originally Posted by trigital View Post
    Change fuel filter.
    Yep mate change the fuel filter, replace the battery , i think this gives to you problems which you will never know from where they comes, then check if the problem persists
    Learn from the mistakes and live the life.
    Jun 2010
    Tenerife
    Hi there, yesterday had full service and more, drain all greabox and replace with new filter & oil, new battery, full service, drain all brake fuild and replace with DOT4, 2 new engine mounts, new sterring pump, new fuel filter.new abs speed senor.
    it strange it now feels slower than before, revs ok, feels like im towing something.
    here are the codes ask for
    P0383
    P0178
    P0173
    P0178
    P0173
    P0301
    P0302
    CAN ANYONE HELP OR ANY IDEA WHAT ELSE I CAN DO, SINCE SERVICE IT HAS GONE INTO LIMP MODE 4 TIMES.
    Tacho Pro 2008
    Jun 2010
    Tenerife
    sorry codes are
    P0303
    P0170
    P0173
    P0170
    P0173
    P0301
    P0302
    Tacho Pro 2008
    Feb 2010
    [QUOTE=pinky1970;800365]sorry codes are
    P0303 cylinder 3 misfire
    P0170. Fuel trim (bank 1 malfunction)..........leakage in air system, intake air leak, EVAP canister purge valve, fuel pressure pump, H02 sensor and injectors
    P0173......Fuel trim (bank 2 malfunction)..........leakage in air system, intake air leak, EVAP canister purge valve, fuel pressure pump, H02 sensor and injectors
    P0170
    P0173
    P0301 cylinder 1 misfire
    P0302 cylinder 2 misfire
  11. #11
    Mar 2009
    Have a look at the map sensor
  12. #12
    hi
    this problem is a airflow meter, vacuum or air leak, or both!
  13. #13
    Jun 2010
    Tenerife
    When you say airflow meter, do you mean air mass senor.
    Tacho Pro 2008
  14. #14
    Feb 2010
    Tirana
  15. #15
    Mar 2010
    did the problem occur b4 changing the plugs or after ?
    if it was doing it b4 then the usual cause is the air mass sensor but the adaptation data will need resetting after replacement as previous posts have mentioned
    the wiring to the coil packs can rub through on the rocker cover bolts
    if the misfire occured after replacing the plugs then more likely to be plug leads swap them to different cylinders and see if the misfire moves
    good luck
    conect
