    Apr 2008
    Default Problem with dreamup
    Hi, Ive just recieved my usb to 9 pin female null modem cable in the post today and followed the post by Kaos on how to flash with dreamup. the box connects ok but when i connect the power to the box when prompted nothing happens and the screen just stays with the prompt"connection prepared now swith on the dreambox!" the power is on but im geting no further than that...any advice appreciated
    Mar 2008
    Coatbridge
    Is Com1 available in your control panel, if not drop down to the BIOS and enable it.
    Apr 2008
    Witchy,
    On the drop down box in dreamup it would only let me select COM3 is this ok..if not could you give me some pointers to enable COM1?
    Cheers
    Apr 2008
    check to ensure if no other USB device driver installed or running at the background, as most of usb devices; mobilephone manager, activesync, hotsync etc... tend to uses com1 as their normal usb to coms translator.
    Apr 2008
    Ive got activesync installed , but this isn,t running, ive closed everything that i think could be interferring with the ports but still only showing port3.. would uninstalling activesync and other programs that are possibly causing the problems be the next step?
    Apr 2008
    Default DREAMUP CONNECTION
    Quote Originally Posted by scurders View Post
    BEFORE PROCEED MAKE SURE ALL CABLE CONNECTED ,UNPLUG THE DREAMBOX POWER SUPPLY.OPEN DREAMUP APPLICATION AND UNTICK NETWORK BAR.NOW CLICK CONNECT AND PLUG BACK POWER SUPPLY.IT WORKS.
