Is there anybody knows how to change Japanese language in 09 das mode?
An english works. no works Japanese language
NIHONNGO HA KANNTANNNI DEKIMASUYO FAIRUNOKAKIKAEHA HITUYOUDESU
I reinstall das and xentry, it's same problem, anyone know how to do ?
for das and das sim, if you extract the thesaur to
c/programme/das/thesaur
then put the following file on your desk top and you will have all lanuages.
You need to use your head when kicking a ball
Old version files work with 2010.09 i used 2010.03
Did you use winrar to extract the files ?
Hi, I did not know that we could use previous file versions with das 09/2010 ! This is a good info.
To read .cab file, I first run regsvr32_cabview.dll, then double click on the .cab file which opens. But this does not work with files on 09/2010 SD DVD (error message).
Yes, I have winrar installed on my PC
Members of the world Friends Hello everybody, I have two questions xentry how to convert a language language translation, please give me a patch, there is one on how to start from the xentry Wis problem. Thank you
I can not open the download address? ? ? ? ? ? ? ? ? ?
I have tried 2010.03 french thesaurus but I'missing some sentences when used with 2010.09 das. Would be better to use 2010.09 one, dont you think so ?
In other words, I would be very grateful if someone could pm this file to me (thesaufr.dbz)
Thanking you in advance,
jmk32120@aol.com
Your observation sounds reasonable. Why would the files be different if they were 100% compatible. Interesting to know anyway that the files are "mostly" compatible.
If you cannot find the file in a couple of days, I'll send it to you. I don't have the time before the day after tomorrow, hopefully someone else has them readily available.
