under construction
under construction
Last edited by manocao; 22nd February, 2012 at 11:45 AM. Reason: under construction
__________________
China: OPEL Tech2 non-CAN multiplexer USB, OP-COM USB, OBDII Elm327 USB, VAG-COM 409.1/VCDS Lite 1.0 KKL USB
Homemade: UNISCAN Visa 1.83 RS-232, Renault XR25PC USB, BMW KKL USB, Nissan Consult1 USB
Any news on this? I?m having trouble to get it to work. Here is a screenshot of what it say?
did u install .net 4?
__________________
Hey there, I can not follow the link on calameo, so there is no way I can use the software. I would really like to try it, can someone help me please?
**Wrong topic** oops
Hi knispler,
Write some words to ask to the author at car-diagnose@live.nl
I got the good link that way!
Philippe
Hi Guys,
Link is not alive...
please can someone uploaded...
THANKS
xr25pc 1.01-3.35 final easy installation
1. install .net 4.0 and reboot:
Microsoft .NET Framework 4 (Standalone Installer) - Microsoft Download Center - Download Details
2. if after installing .net 4.0 your computer becomes slower when booting and network interfaces doesn?t appear after a while, run this in a console (cmd or make a .bat file with this):
c:
cd C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727
ngen update
cd C:\Windows\Microsoft.NET\Framework\v4.0.30319
ngen update
pause
if you are not sure if your system has become slower, you can do it anyway anytime, it will not harm your pc, it just reorganize-optimize .net 4.0, makes booting faster, fix things, doesnt make any bad
then you can additionally run services.msc and disable these two services: .NET Runtime Optimization Service v2.0.50727_X86 and Microsoft .NET Framework NGEN v4.0.30319_X86
3. here is "xr25pc -all versions- easy installer", install and follow the instructions (it is important that you copy-paste the fonts through 'control panel' > 'fonts'):
ASK BY PRIVATE MESSAGE (check your inbox is not full)
maybe it needs administrator rights to install
it includes info for building ftdi interface
__________________
here is last version 3.35 with original installer by R. Koster car-diagnose@live.nl
run install-first.bat, then setup.exe
edit: file was deleted
of course, .net 4 framework must be installed in your system
you don't know if it is already installed? run this or this
__________________
Ok mate , I have an question :
My last version is 3.31 full installed , I need uninstall old version to install this 3.35 ?
Thanks.
no need to uninstall
if your 3.31 is working right, you dont need to upgrade
__________________
http://www.digital-kaos.co.uk/forums...easy-installer
final thread, easy installer, great compilation, with all best resolution fiches in english...
__________________
srscrash (4th October, 2013)
If anyone is still here I will be thankful if anyone can help me connect to a Twingo 95. Mainly how to use the Xr25pc
