Page 3 of 11 FirstFirst 12345678 ... LastLast
Results 31 to 45 of 164
  1. #31
    May 2009
    I installed it right as far as I know. I used a 2008 database that came with the download, It's v2.3.0.1 and v2.0.9.0 I've tried.
  2. #32
    Elsewhere
    @spikyhercules : I use if USB - serial with FT232 ( the only one chip I found to work with DDT ), if with USB - serial converter with PL2303 do not work, DDT is very sensible on time delays by this chip. I attach for you the schematics I use with success, made this and you will be OK.
  3. The Following 3 Users Say Thank You to alfabit For This Useful Post:
    gameiruz (1st September, 2014), martinracing (6th September, 2013), svallecilla (25th July, 2023)
  4. #33
    May 2009
    Do you have that layout in a higher resolution?
    Do you mean you plug your cable into PC via serial port ?
    My cable is this exact one 006 UK VAG-COM USB DIAGNOSTIC CABLE 409.1 OBD2 VAG COM on eBay (end time 01-Nov-10 18:57:12 GMT)
    I opened my cable and the chip on the board is FT232. I think I just need the right drivers. It came with VAG-COM drivers and nothing else. It was the bloke who makes the XR25PC that told me the cable 'should' work. Just trying things on XP now to see if that makes a difference.
  5. #34
    Elsewhere
    I plug the cable via USB, not serial. The layout depends on the case you use. I put all that schematic inside the case of the OBD connector. You must find an OBD connector and make the layout according to your OBD conn.
    The drivers for FT232 you find on ftdichip.com, the manufacturer of that chip, actual ver 2.08. Down the drivers from them and it will work no doubt, it is the best chip for that kind of applications, very little delay, OK for DDT2000
    You want the schematics on higher resolution ? If yes, I can attach in higher res. Higher res attachement :
  6. The Following 2 Users Say Thank You to alfabit For This Useful Post:
  7. #35
    Birmingham UK
    @spikyhercules blue kkl cable does work with ddt I got one. go to ddt database and have a look how big is your data file max available for download is over 400mb. Also use ddt drivers for cable it's in instalation folder. I don't think ddt works with vag drivers as I think I had same problem untill I have used ddt drivers.
  8. #36
    May 2009
    Quote Originally Posted by gregk View Post
    My DDT database is 398mb. When I try installing the Derelek drivers via device manager they make my COM port disappear Tried them on windows 7 and XP both x32.
  9. #37
    Birmingham UK
    That is odd. I've installed ddt drivers first then plugged the cable in and allowed it to choose it's own drivers and no problems running it.
    Do you connect the cable to laptop first then switch the ddt ON? This is the only way program will recognise com port. Also you need to allow active x to run on first screen.
  10. #38
    Why can not I install XR25PC always gives error
    Can you teach me step by step how to install in windows xp
    the error is:
    The Dfsvc.exe ebcontrou a problem and must be encerrado.Lamentamos any inconvenience this may cause
    excuse de traduction
  11. #39
    Quote Originally Posted by Spikyhercules View Post
    which database du you use? i only have 40mb... sick!
    lets be friends, maybe you can send me yours
    Quote Originally Posted by zeca View Post
    the error is:
    this seems to be a failure of your system. or a damaged download.
  12. #40
    May 2009
    Tried it mate, I always have the cable plugged in before I load DDT, Yes I get the activex popup which I allow.
    I have noticed my car is ISO8 and the icon near my ECU is pink ...These cables do support ISO8 right?
    Also what version of windows are you using? And what version of DDT2000?
    the error is:
    Are you installing v1.15 first?
    Also in the readme file it says at the bottom...
    copy ftd2xx.dll to c:\windows\sytem32
    make a directory c:\website\CLIP\resources
    copy the image files in this directory (resources.rar)
    copy the font files c:\windows\fonts
    run setup
    Hope that helps
  13. #41
    DK Veteran manocao's Avatar
    try uninstalling ftdi drivers first with ftclean:
    http://www.ftdichip.com/Support/Utilities/FTClean.zip
    then install interface with dtt2000 drivers
    edit: driver included in C:\Program Files\DDT2000\Install_Driver\ is for original derelek interface only
    USB\VID_0DAA&PID_0FE7.DeviceDesc="DERELEK Diagnostic USB interface"
    USB\VID_0DAA&PID_0FFF.DeviceDesc="DERELEK OPTO Diagnostic USB interface"
    USB\VID_0DAA&PID_1045.DeviceDesc="DERELEK Diagnostic (CAN LSFT) USB interface"
    USB\VID_0DAA&PID_104F.DeviceDesc="DERELEK Diagnostic USB interface 2"
    USB\VID_0DAA&PID_109A.DeviceDesc="Derelek USB-DIAG3 (renusb)"
    USB\VID_0547&PID_2235.DeviceDesc="Cypress EZ-USB (2235) - EEPROM missing"
    USB\VID_0547&PID_2236.DeviceDesc="Cypress EZ-USB (2236) - EEPROM missing"
    USB\VID_0547&PID_2225.DeviceDesc="Cypress EZ-USB (2225) - EEPROM missing"
    USB\VID_0547&PID_2226.DeviceDesc="Cypress EZ-USB (2226) - EEPROM missing"
    USB\VID_04B4&PID_8613.DeviceDesc="Cypress EZ-USB FX2 - EEPROM missing (RenUSB)"
    that driver wont work with your interface whose ft232 chip is factory set to VID_0403&PID_6001
    cheap vag com kkl interfaces dont have eeprom
    if your ft232 interface had an eeprom, maybe you might edit it with mprog to any vid and pid like above
    the error is:
    maybe you are using version 1.01 or 1.02 which are defective
    download latest and follow instructions:
    XR25 latest download location
  14. #42
    May 2009
    Here is what happens when I try installing the Derelek driver...
    The above errors could be because I dont have the eeprom?
    This is how device manager is with no drivers installed and the cable plugged in...
    DDT2000 looks like this when I have standard FTDI drivers installed...
    <<< Click
    I've just noticed in the 'Diagnostic Interfaces' window it says '10/29/2010 5:30:27 PM : Error 91 : Object variable or With block variable not set' Everytime I select any ports...
  15. #43
    May 2009
    I've finally got the diagnostic interface log icon half and half and the log says
    '29/10/2010 20:52:29 : Running on
    29/10/2010 20:52:29 : Requesting config file file:///C:/Program%20Files/DDT2000/DevDiagFirmware.xml
    29/10/2010 20:52:29 : Got config file
    29/10/2010 20:52:29 : Read Firmware File Online Or Offline
    29/10/2010 20:52:29 : Starting Enumeration
    29/10/2010 20:52:29 : Info : Define key 'HKEY_CURRENT_USER\Software\VB and VBA Program Settings\DDT\Hardware\AllowUSBDIAGUpdate' as non empty string to authorize USB-DIAG firmware update
    So I'll connect it to the car tomorrow and see what happens.
  16. #44
    Birmingham UK
    Xp pro and 2.3.0.1 Not sure on iso8 as the only cars I've connected was various kangoo diesel, 1 petrol kangoo and Laguna 2 2001, I know it will not connect to early kangoo pre 2000 diesel with lucas hom ecu.[can't remember if it's due to lack of data] I couldn't get com port to work on dell inspiron 4150 but works a treat with hp nc6000.
    Just had a look at your pic did you try a scan for all cars? I couldn't get lag 2 to connect by scaning laguna 2 but did connect after scanning for all cars.
  17. #45
    May 2009
    On my 2nd to last picture above, on the project information bit does it look like yours does?
    Also, the icons near the clock, blue one is always blue. But the yellow one, do I have to be plugged into the car to get both arrows or can I get both arrows by DDT finding my cable before being plugged in to car?
