Page 2 of 11 FirstFirst 1234567 ... LastLast
Results 16 to 30 of 164
  1. #16
    Mar 2010
    problem solved!
    version 1.21 is released, a scrollbar is included!
    it is such a pleasure to have contact with a person like that author!
    christian
  2. #17
    May 2009
    This sounds like it could be very handy for me. I have a 1996 megane coupe 2.0 16v and have wanted to read data for ages! Can anyone confirm they have managed to get all the parts in the uk?
  3. #18
    DK Veteran manocao's Avatar
    Sep 2009
    he has released new version 1.21 with scroll problem fixed
    XR25 latest download location
  4. #19
    Sep 2009
    it's true, very helpy author! i have thanked him lots of times
    Quote Originally Posted by clio16s View Post
    problem solved!
    christian
  5. #20
    May 2009
    Can anyone advise on this ...I have a 1996 Megane Coupe 2.0 16v - DA0H - F7R engine. My diagnostics plug is in the pic below and its an OBD plug. Do I have the 12 pin socket somewhere on the car?
  6. #21
    Sep 2009
    your connector is obd2 16pin
    you can also use xr25pc with kkl interface like cheap vag com 409.1 from ebay
    ask author if f7r engine is supported
  7. #22
    May 2009
    I messaged the author, he said it won't work on mine as my ECU is Fenix 5 and I should try DDT2000. Just downloaded the software and bought an ELM323 from ebay in the hope that it works.
    Edit** Would the 323 cable work OK or do I need the KKL one you mentioned or do you know if the 323 will work with DDT2000?
    Thanks for your help
  8. #23
    Jan 2010
    Elsewhere
    No way 323 work with ddt2000. You need kkl interface or dedicated interface for ddt2000 ( schematics posted somewhere here on dk )
  9. #24
    May 2009
  10. #25
    Sep 2009
    yes, it is SUPPOSED that ddt2000 will work with that kind of vag com 409.1 kkl "blue cable" cheap interface (also sold in black colour but is well known as "blue cable")
  11. #26
    May 2009
    Excellent, I bought one last night so will give it a go when it arrives
  12. #27
    May 2009
    The vag-com 409.1 cable arrived today. Plugged it in, installed drivers, checked it was working with vag-com software, all fine. Started DDT2000, plugged cable into the car, LED lit up on cable, in DDT2000 I could select COM3 but it doesn't seem to do anything at all. is there any way i can tell if DDT is using the cable? or a link to a DDT2000 manual? Also what driver should I use with the cable as DDT2000 has its own drivers... I'm totally lost.
  13. #28
    Jan 2010
    Elsewhere
    You must select the COM that appear by plugging-in the cable you bought. DDT works only on COM ( USB - serial COM in control panel ), you can`t tell DDT the type of cable you are using, or original CAN interface ( not your case )
    I never use cables bought, I use cables ( interfaces ) made by me because I know what I am doing .
  14. #29
    May 2009
    If I knew exactly what sort of interface I need and could find the schematics for it I'd build it.
    My cable has COM3 set in device manager and DDT shows that COM port on the Hardware > Diag port bit. I select it, click OK then it takes me to Scan part of DDT. I click the binoculars for all, DDT starts scanning flashes up with 'ISO8?' on every test then says none.
    What drivers do you use for your cables/interfaces used for DDT?
    My ECU is Fenix 5 if you know of anything that will read it?
  15. #30
    Mar 2010
    are you sure, that you installed DDT right?
    wich database do you use?
